Closed and Exact Forms on 2-Torus: Solving for Global Definitions and Exactness
  • Thread starter Thread starter Breo
    Closed Forms
Breo
Now consider a 2-torus ## S_1 × S_1## and a coordinate patch with coordinates ## (\alpha_1, \alpha_2)## such that ## 0 < \alpha_i < 2 \pi##. Let us introduce in this patch a 1-form of the type:
$$\omega = (A + B\alpha_2 + C sin(\alpha_2 ) + D cos(2\alpha_1 + \alpha_2 ))d\alpha_1 + \phi(\alpha_1 , \alpha_2 )d\alpha_2$$
a) Try to determine the possible values of the function ##\phi(\alpha_1 , \alpha_2 )## so
that the form ##\omega## is closed.
b) For what values of A, B, C and D is the closed form globally
defined?
c) For what values of A, B, C, D and ##\phi## is the form exact?
A form is closed when satisfies: ##d\omega=0##
The necessary and sufficient condition for a closed r-form ##\omega## to be exact is that for ##b_r## independent cycles in ##C_a \in H_r## the periods vanish: $$ \int_{C_a} \omega = 0$$
[/B]
a) Using the equation of the exterior derivative and knowing that ##d\omega = 0## I wrote:
$$ 0 + (\frac{\partial B\alpha_2}{\partial \alpha_1}d\alpha_1 + \frac{\partial B\alpha_2}{\partial \alpha_2}d\alpha_2)\wedge \alpha_1 + ... = \Bigg( \frac{\partial \phi (\alpha_1, \alpha_2)}{\partial \alpha_1}d\alpha_1 + \frac{\partial \phi (\alpha_1, \alpha_2)}{\partial \alpha_2}d\alpha_2 \Bigg) \wedge d\alpha_2$$
Using the Poincarè lemma ##d^2=0## and the relation ## dx^i \wedge dx^j = -dx^j \wedge dx^i ## I finally obtained:
-B d\alpha_1 \wedge \alpha_2 = \frac{\partial \phi (\alpha_1, \alpha_2)}{\partial \alpha_1}d\alpha_1 \wedge \alpha_2 $$
Not sure how to resolve this, maybe: ## \phi (\alpha_1, \alpha_2) = -2\pi B ## ?
b) Do not know... it is when the coord charts are defined for all values of a parameter? Sorry I do not know.
c) No idea. I get lost when read the de Rham cohomology theory, etc.
What happened to the terms involving C and D?
I'm not 100% positive what the question is asking for, but if \alpha_1 and \alpha_2 are angles, then that means that \alpha_1 = 0 is the same angle as \alpha_1 = 2 \pi, and similarly for \alpha_2. That means that a globally defined function should be periodic in \alpha_1 and \alpha_2.
A 1-form \omega is exact if there is a function f(\alpha_1, \alpha_2) such that \omega = d f. So you're just being asked when it is possible to find such an f.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
25K
