Excess electrons or protons on drop.
The discussion centers on calculating the number of excess electrons or protons on a small water drop suspended in an electric field of 8450 N/C. A participant expresses confusion over their calculated charge of approximately 4.1071 x 10^-12 C and the resulting number of charges, which they believe to be incorrect. Another contributor points out that the discrepancy may stem from a misunderstanding of whether to divide or multiply by the charge of an electron. The conversation emphasizes the importance of correctly applying formulas and understanding the relationship between charge, mass, and electric field strength. Accurate calculations are crucial for determining the correct number of excess charges on the drop.
rcmango
A small drop of water is suspended motionless in air by a uniform electric field that is directed upward and has a magnitude of 8450 N/C. The mass of the water drop is 3.80 10-9 kg.
(b) How many excess electrons or protons reside on the drop?
i'm not sure what I'm doing wrong, but i get about 4.1071 x 10^-12 C
and for the drops i get 2.754 x 10-31
not sure why its wrong?
i used this for formula, see image: http://img180.imageshack.us/img180/6734/80350082pv3.png
I'm not sure what you're asking here really. I presume the image is the answer to the question and you're wondering why yours is different. From the 2.754x10-31 it appears you've multiplied the charge on the drop by that on a proton.
well the image has different values to be calculated, and the image was just another example to show what was going on,
the problem i calculated was different, but it should still be calculated the same.
and it should be: 2.75e+07 but not sure why?
I'm getting slightly different numbers than you, but are you sure you're dividing by the electron charge and not multiplying? That's the only way I can see you getting an answer with that magnitude.
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
