Solving Weak Interactions: W- vs W+
Weak interactions involve the exchange of W- or W+ bosons, with beta minus decay associated with W- and beta plus decay with W+. Understanding which boson to use in unknown reactions can be challenging, but charge conservation plays a crucial role in determining the appropriate interaction. W bosons are primarily involved in quark flavor changes, and for A-level students, focusing on memorizing specific reactions is advisable due to the complexity of W boson behavior. The emission or absorption of W bosons adds to the confusion, but grasping the basics of charge conservation can aid in identifying the correct interactions. Mastering these concepts will enhance comprehension of weak interactions in particle physics.
fabbo
Well its not really a homework question but I have looked through the tutorials and am still at a loss.
During weak interactions the particle exchanged is either W- W+ or Z0. The thing is, I get confused which weak interactions involve W- and which involve W+. I know beta minus decay is W- and beta plus W+ but how do I work it out for an unknown reaction?
Is charge conservation involved, if so how?
Any guidance would be much appreciated.
W bosons are primarily seen in quarks flavour changes. I take it you are doing A-levels, or equivalent. If you are don't worry about the rules and just learn the few reactions you're given. I say this because W bosons can either be emited or absorbed which makes it a bit more difficult.
