Expansion in non-adiabatic Otto / Diesel cycles
This discussion revolves around the behavior of temperature and pressure during the expansion phase of non-adiabatic Otto and Diesel cycles, as well as the implications for real heat pumps. Participants explore how energy dynamics affect these variables in practical scenarios, questioning the relationships between temperature, pressure, and density.
  • Some participants question how energy can enter the system to increase temperature without increasing pressure during expansion.
  • Others suggest that the density change must be considered, as described by the ideal gas law, where pressure, temperature, and density are interrelated.
  • There are claims that energy is leaving the system during expansion as work is done, rather than entering it.
  • Some participants argue that heat added by friction or inefficiencies contributes to higher temperatures than predicted by ideal processes.
  • Concerns are raised about how the number of particles remains constant while density changes, with explanations pointing to volume changes during expansion.
  • There is a suggestion that high temperature should correlate with high pressure, but this is contested based on density considerations.
  • A later reply mentions that the solution may involve understanding polytropic processes, though details are not provided.
  • One participant notes that pressure remains above ambient levels at the end of the expansion stroke before further expansion occurs, indicating additional energy extraction mechanisms in play.
Participants express differing views on the relationships between temperature, pressure, and density, indicating that the discussion remains unresolved with multiple competing perspectives. There is no consensus on how these variables interact in non-ideal conditions.
Limitations include the need for specific values for pressure, temperature, and density to fully understand the dynamics at play, as well as the complexities introduced by real-world inefficiencies and heat losses.
racctor
TL;DR
How can temperature be conserved while pressure drops in non adiabatic expansions/compressions?
Hello!
I have a question that has been bothering me for a while now. If we look at the expansion step of a real otto or diesel cycle we see that while the pressure drops to near surrounding levels the temperature remains relatively high ( high T of the exhaust gas). How is that possible? How can energy enter the system that increases the temperature, but not the pressure? Or in other words, how can energy dissipate into kinetic energy of the gas but not increase the pressure?
I think the same problem occurs for me in the compression step of real heat pumps: If i add work to a real system to reach a certain pressure, how come the temperature of real systems is higher than in the ideal isentropic compression?
If we take into account that in those examples we experience some heat loss to the surroundings, wouldn't that just decrease the mechanical Work i can get out of the system, but since heat is lost, the temperature drop should be the same as the pressure drop?
Your help is very much appreciated
kind regards
Because the density has also changed. ##P = \rho RT##, there are 3 variables in the ideal gas law.
Because of heat added by friction or other inefficiencies.
It does.
Again, there is a density change to consider as well.
Energy isn't entering the system during the expansion phase. It's leaving the system, because the system is doing work.
Energy isn't dissipating into kinetic energy of the gas during the expansion phase (except for a small amount due to friction losses, but in the idealized case these are zero). It's being used to do work.
It does.
Thanks for your answer
How can the density change if the number of particles stays the same?
Friction or heat loss to surroundings would only increase the T of the surroundings though?
kind regards
Um, because the volume is changing due to expansion?
Let me rephrase it: How can the temperature still be so high although the work has already been done ( and pressure has dropped to near atm level)? High temperature should still cause high pressure?
wouldn't that also happen in an ideal process?
Not if the density has decreased. You are simply waving your hands instead of doing the math. Try looking up some actual values for all three variables--pressure, temperature, and density--before expansion and after expansion, plug them into the ideal gas law, and see how they match up. That is going to be a much better strategy than trying to guess based on your intuition.
Of course it would. So what? @jack action wasn't arguing that the density change only happens in a non-ideal process. He was arguing that you are simply ignoring density change, even in the ideal case, and acting as though temperature and pressure are the only things that can vary, even in the ideal case. They're not.
Again, don't wave your hands, do the math.
okay, will try. I hope it isn't too complicated. I am actually studying something completely different.
Thanks for the input!
Who says that the temperature would stay high? It would be lower at the end.
If anyone else is looking for an answer to my question; the solution apparently can be found in "polytropic processes"
kind regards
Please elaborate.
It's worth mentioning that at the bottom of the expansion stroke (power stroke) in an engine, before the exhaust valve opens, the pressure is still substantially above ambient. It doesn't drop to ambient until it is allowed to expand further in the exhaust system, often through a turbine that extracts yet more energy from it.
  • · Replies 19 ·
  • · Replies 16 ·
23K
