Explosion of one mass into three
  • Thread starter Thread starter haroldham
    Explosion Mass
A 4.2 kg object explodes into three equal mass pieces, with two pieces moving at 5.0 m/s at right angles. The conservation of momentum principle helps determine the velocity of the third piece, which is necessary for calculating the total kinetic energy. The kinetic energy of each piece can be calculated using their masses and velocities. The total kinetic energy released in the explosion is approximately 103.5 J. This calculation highlights the importance of understanding momentum and energy conservation in explosive events.
haroldham
A 4.2 kg object, initially at rest, "explodes" into 3 objects of equal mass. Two of these are determined to have velocities of equal magnitudes (5.0 m/s) with directions that differ by 90 degrees. How much kinetic energy was released in the explosion? (that is what is the energy of the three object systems after the explosions)
To be honest, my teacher did not cover this in class so I'm naked in the dark on this one.
Since they are at 90 degrees to each other, one would be 5 j m/s and the other would be 5 i m/s. I am not sure where to go from there or where the third factors in.
Since the center of mass remains the same from conservation of momentum, then first figure the velocity of the third object. (Happily you can because you know the mass of all 3 pieces are equal.)
Then you know how much KE each piece has since you know their masses and velocities.
Ok, thank you so much. I undertand.
Did you get 103.5 J?
Perhaps you should show your calculation?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
