Extracting a constant variable from integral
A constant variable "b" can be extracted from an integral through substitution, which is a valid technique in calculus. When changing the variable of integration, the differential d(x/b) simplifies to dx/b, allowing the constant to be factored out. This manipulation demonstrates how integrals can be adjusted by altering the variable being integrated. The discussion emphasizes that this method is a useful trick for handling integrals. Understanding this concept is beneficial for those studying classical physics and calculus.
shanepitts
Sorry for the simplicity of the question but I encountered a simple math problem whilst autodidacting myself on classical physics. I seen that a surplus of a specific constant variable "b" was extracted from an integral after a bit of manipulation.
∫xdx was turned into b2∫(x/b)d(x/b)
Does the extra constant b come from the d(x/b)? If so, or if not, how can one change what the integral is being integrated with respect to?
This question is a not a homerwork question.
Thank You
Mathematics news on Phys.org
If b is a constant, then yes that is valid. We can change the variable you are integrating with respect to, with substitution, and it's a nifty trick for integrals.
d(x/b) is jus dx/b or (1/b) dx so you can take the constant term out like that.
Likes shanepitts
Awesome, thanks a bunch
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
