F = ma 2007 Exam - Question #25 - SHM with a box in water
The discussion focuses on calculating the period of small oscillations for a water pogo, a box-shaped object bobbing in water. The buoyant force is identified as the restoring force, and participants explore methods to derive the period from this force. One approach involves equating gravitational potential energy with the work done by buoyancy, while another suggests using the sum of forces to set up a differential equation. The conversation highlights that understanding the physics is crucial, as the exam question is designed to test both conceptual knowledge and mathematical skills. Ultimately, the goal is to recognize that the problem parallels the behavior of a mass on a spring in simple harmonic motion.
physicsod
Find the period of small oscillations of a water pogo, which is a stick of mass m in the shape of a box (a rectangular parallelepiped.) The stick has a length L, a width w and a height h and is bobbing up and down in water of density ρ. Assume that the water pogo is oriented such that the length L and width w are horizontal at all times. Hint: The buoyant force on an object is given by Fbuoy = ρVg where V is the volume of the medium displaced by the object and ρ is the density of the medium. Assume that at equilibrium, the pogo is floating.
Fbuoy = ρVg.
Fg = mg
So I created the general box (or "parallelepiped") and set it's dimensions as L, w, and h. I let the height underneath the water be "a," where a is some fraction of h. Then, the buoyant force is Fbuoy = ρLwag. But how do I extract the period from this equation?
The bouyant force is the restoring force.
Your parameter "a" is the bit that has SHM.
Well yeah, I understood that bit. Is there a general way to go from the restoring force to a general SHM equation?
EDIT: I just thought of setting the gravitational potential energy (mga) equal to the work done by the buoyancy force, for conservation of mechanical energy. Is this correct?
Ahhh... the usual way is just to set ƩF=ma ... so it is unfortunate that you have used a as your emmersion parameter.
If h0 = the equilibrium level, then set y = displacement from equilibrium downwards, thus: \vec{F}_{bouy}+\vec{F}_{grav}=m\ddot{\vec{y}}, resolve the forces in terms of m and y, and solve the differential equation.
Approximate for small a small initial downwards displacement y0 ... which will become the amplitude of the oscillations.
Yuck, so this is a basic diff eq question? Darn, well I guess that's expected for question 25 on the exam. I'll try that out, thanks. :)
Yeah - though it has a standard solution - like the mass on a spring: buoyancy standing in for the spring force. So, if you understand the physics you can just do it by substitution.
They don't really expect you will solve the DE in an exam - that's just to slow you down if you didn't understand the material. Too little understanding and you won't be able to complete the exam. Sneaky see - ideally they want you to understand what you are doing but if you are really fast at the math, well, that's good too. Most people do a bit of both.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
