Falling brick speed - equation needed
  • Thread starter Thread starter [Cat]
    Falling Speed
To determine the speed of a brick falling from rest through a distance of 20 meters, the relevant equation is derived from the principles of conservation of energy. The formula v² = u² + 2as applies, where v is the final velocity, u is the initial velocity (0 in this case), a is the acceleration due to gravity (approximately 9.8 m/s²), and s is the distance fallen (20 meters). Substituting the values, the final speed calculates to approximately 19.8 m/s. This approach effectively relates the initial and final energies of the brick during its fall. Understanding these equations is crucial for solving similar physics problems.
[Cat]
I have a question in my work book that I cannot solve as I can't find the correct equation. The question is:
What speed will the brick have after falling through a distance of 20 metres? U= at rest. There are no other constants given. What equation would I use to solve this problem?
(I have looked in the back of the book and the answer is:19.8 m/s)
Thanks,
Cat.
Think conservation of energy. Compare the initial and final energies at each state and equate them.
v**2=u**2+2as
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
