Falling mass onto flat plate pressure exerted
The discussion revolves around designing an experiment to measure the effect of pressure on grass seed germination using a flat plate. The user can exert approximately 15-16 kPa by standing on the plate and seeks to achieve around 30 kPa through jumping. Suggestions include using a frame to apply continuous pressure instead of jumping, as the latter would only create temporary pressure. The user acknowledges the complexities of soil dynamics but prefers to keep the experiment straightforward, mentioning a control area for comparison. Overall, the focus is on determining an effective method to simulate pressure on the seeds without overcomplicating the setup.
llamedos
hi I'm trying to design a small experiment based on soil pressure
i've not had much use of some of the equations and principles for a few years so I'm a little rusty
basicly I'm trying to exert pressures onto grass seeds (lolium perenne) in a rough field experiment in order to see how it affects germination rates
effective material
small flat plate 0.25m*0.25m for this purpose it is effectively massless
me approx mass 100kg
i can exert approx 15-16kPa by standing on the plate
but I'm trying to calculate how high i need to jump to exert around 30kPa
looking for a max pressure
i'd assume soil compression to be about 2 cm from surface height
i don't need high precision but a rough and ready approximation
ignore any mitigation by the body i.e knees and ankles
any help gratefully received
mass m = 100kg
grav = g = 9.8m/s^2
area = a = 0.0625m^2
welcome to pf!
ih llamedos! welcome to pf! :smile:
but I'm trying to calculate how high i need to jump to exert around 30kPa …
jumping will only exert a very temporary pressure, probably totally useless for your purposes
easier would be to erect a frame with a bar going over your head, so that you can push up against it to press down on the plate continuously …
and you can put ordinary bathroom scales on the plate to show you the force
btw, i assume you'll have a control area with an identical plate with no pressure on it? :wink:
its a form of simulated rolling so effective time period is about 0.1 seconds and lower
which is similar to the exertion period of jumping on it
yes there is a control i don't do anything to it
but i could get lost in the complexities of soil matrix dynamics under compressive forces and incident periods so i don't want to.
also when i say field i literally mean field
cutting a plate with half the area and using it twice could work but then there would be the challenge of compensating for more edge effects
on another note i joined back in 2007 when i was doing my a-levels been lurking ever since but never really needed to ask for assistance
(if you want to simulate rolling, why not use an actual roller? :confused:)
let's see … if a roller with mass M passes over the area of a plate in time t,
then that's an impulse (force times time) of Mgt​
if your own mass is m, and your centre of mass rises by a height h (from crouch position to maximum position), then the impulse is the initial change in momentum, = mvi, = m√(2gh)
(if you both jump from the plate and land on the plate, then that's multiplied by 2)
so for the same effect you need h to be (M/m)2t2g/2
