What Is the Angular Speed of a Falling Ruler at 30 Degrees?
  • Thread starter Thread starter Ruitker
    Falling Freefall
The discussion focuses on calculating the angular speed of a falling ruler at a 30-degree angle from the vertical, given its mass and length. Participants debate the best approach to solve the problem, with suggestions including conservation of energy and equations of motion. One participant emphasizes using the equations of motion applied to the end of the ruler, considering the effects of gravity and the rigid structure of the ruler. There is uncertainty about whether to calculate linear velocity first or directly find the angular velocity. Overall, the group is seeking clarity on the correct method to derive the angular speed at the specified angle.
Ruitker
A ruler stands vertically against a wall. It is given a tiny impulse at θ=0∘ such that it starts falling down under the influence of gravity. You can consider that the initial angular velocity is very small so that ω(θ=0∘)=0. The ruler has mass m= 250 g and length l= 25 cm. Use g=10 m/s2 for the gravitational acceleration, and the ruler has a uniform mass distribution. Note that there is no friction whatsoever in this problem.
(a) What is the angular speed of the ruler ω when it is at an angle θ=30∘? (in radians/sec)
The angle is from the vertical.
I'm not sure on which method to use. I was thinking either conservation of energy or using the centre of mass equations.
Various attempts that have not yielded correct answers.
Personally, I wouldn't use either "conservation of energy" or "center of mass". I would apply the equations of motion to the end of the ruler. You know that the downward acceleration is always "-g" (-9.82 m/s^2). But the rule cannot fall straight because the ruler is "rigid". So separate the vector <0, -g> into one component along the length of the ruler and one at right angles to the ruler at each angle. Only the perpendicular component acts accelerates the end of the ruler.
Thanks for your suggestions. I am not sure i understand what you mean. Shall i calculate the velocity and then convert to angular velocity or is there a trick i am missing.
Isn't it better to write equation of motion for center of mass?
We need to find ω(θ) relationship. And to do this. Well, I am stuck too with this problem.
