Falling sphere method to find fluid's viscosity
The discussion focuses on using the falling sphere method to measure the viscosity of water, highlighting the importance of the sphere-to-container radius ratio to avoid inaccurate viscosity values. Concerns are raised about using modeling clay as a sphere and the suitability of water as the medium, as the sphere's rapid descent may indicate a Reynolds number that is too high for accurate measurements. Participants suggest using smaller, lighter spheres, like plastic beads, to ensure valid experimental conditions. The need for multiple measurements to reduce random errors is emphasized, while systematic errors related to experimental conditions are acknowledged. The results obtained with glycerin showed a viscosity close to the accepted value, but discrepancies in density measurements raise questions about potential errors in the experiment.
omicgavp
We are performing an experiment to determine the viscosity of water using the falling sphere method. I understand that the ratio of the radius of the sphere to the radius of the container has to be within a certain range in order to avoid a false high viscosity value. And a correction factor is needed in the analysis so that the effects of the container walls and ends will be accounted [ref. G.E. Leblanc,et.al., "The Measurement, Instrumentation and Sensors Handbook", Chapter 30:Viscosity Measurement].
We would like to vary the mass and radius of the sphere and calculate the average viscosity. So we would be needing different spheres. Is it ok to have a modelling toy clay as a sphere? We found out that the mass of the clay, which was molded to a sphere, does not change even after it is put into water. Is it also ok to have water as the medium for the sphere? It is observed that the sphere falls through the water quickly. In our experiment, we used a container similar to a beaker but a few inches taller. We also used a camera and the LabVIEW program to record the motion of the sphere. The sphere experiences g (this can be seen by a slight parabolic curve from the y vs. t plot) at a very short time and then abruptly attains terminal velocity (this can be seen from the slope of the the positive straight line from y vs. t also).
I would like to reiterate my questions:
-Is it ok to have a modelling toy clay as a sphere?
-Is it also ok to have water as the medium for the sphere?
The dynamic viscosity we measured has a discrepancy of about 10^-3 from the accepted value. Do we need to increase our number of measurements to obtain an accurate value? Your thoughts about this would be greatly appreciated.
Repeating the experiment without changing anything will reduce the random errors (for example inaccurate velocity measurements, the ball is not perfectly spherical, etc) but it will not affect any systematic errors, for example if the conditions in the experiment don't match the assumptions in the equations you used to calculate the viscosity.
The most important assumption is that the velocity is small enough. Check what your textbook says about Reynolds number, how to calculate it, and what range it should be to make the experiment valid.
Most likely, your clay sphere is too big and falls too fast. To measure the viscosity of water accurately this way, you need a small light sphere, for example a small plastic bead.
@AlephZero:
What textbook can you recommend because the reference stated doesn't mention about Reynolds number?
Almost any text on fluid dynamics should cover this. I'm surprised your measurement handbook doesn't state the required conditions for the method to be accurate, even if it didn't explain the theory behind them.
Try this:
http://www.mech.northwestern.edu/ME224/ME224_Lab_6.pdf
Here is a different way to correct the results for fairly small Reynolds numbers:
http://www-users.aston.ac.uk/~norriswt/WTNPapers/Sphere%20Viscous%20Fluid.pdf
We used glycerin instead of water so that our reynolds number would be much less than unity. Then corrected the results using the empirical formulas from the handbook; still conforming with the range 0.16</=(radius of sphere/radius of container)</=0.32 [Leblanc, et. al.]. The dynamic viscosity that we obtained is equal to 1.603kg/m.s @ 24 deg. C. It's near from the accepted value. We also obtained the value of the density of glycerin to be 1602kg/m^3 still @ 24 deg. C. Our density is too far from the accepted value of 1261kg/m^3 @ 25 deg. C [ref. J. Cimbala, Y. Cengel, "Essentials of Fluid Mechanics", Appendix 1]. What could be wrong?
Thread 'I need a concave mirror with a focal length length of 150 feet'
I need to cut down a 3 year old dead tree from top down so tree causes no damage with small pieces falling. I need a mirror with a focal length of 150 ft. 12" diameter to 36" diameter will work good but I can't think of any easy way to build it. Nothing like this for sale on Ebay. I have a 30" Fresnel lens that I use to burn stumps it works great. Tree service wants $2000.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
