Faraday's Law and electron force
The discussion focuses on calculating the force exerted on an electron at point P2 due to a time-varying magnetic field described by the equation B = (8.00t^3 - 4.00t^2 + 0.800) T. The initial attempt to use the equation E = -0.5r(dB/dt) was deemed incorrect for point P2, as it applies to a different scenario. Participants highlighted the need to derive a suitable equation for point P2 using Faraday's law. The correct expression for the electric field E was identified as E = [R^2(24.0t^2 - 8.00t)]/(2r), which incorporates the radius of the circle and the electron's orbit. This adjustment is crucial for accurately calculating the force on the electron.
Ithryndil
For the situation described in Figure P31.32, the magnetic field changes with time according to the expression B = (8.00t^3 - 4.00t^2 + 0.800) T, and r2 = 2R = 5.00 cm.
Figure P31.32
(a) Calculate the magnitude and direction of the force exerted on an electron located at point P2 when t = 2.00 s.
E = -0.5r(dB/dt)
F = qE + (qv X B)
E = -0.5r(dB/dt)
F = qE + (qv X B)
Alright, the force equation should simplify to just F = qE because B is zero outside the circle.
When I plug in and get:
F = 0.5qr (24t^2-8t) and plug in for the values:
q = 1.602 x 10^(-19)
r = 0.05m
t = 2
I get: 3.204 x 10^(-19) which is wrong...
What am I doing wrong here?
Hi Ithryndil,
Figure P31.32
E = -0.5r(dB/dt)
I believe this is where your error is; this equation is not correct. How did you get it, and do you see what it needs to be?
The equation is right out of my book.
My guess is that in your book it is part of an example problem; in your diagram for example that equation would apply to the point P1, but not to point P2.
You need to derive an equation that applies to point P2, starting with Faraday's law.
Alright, yeah looks the equation applies to inside the circle, not to the outside...alright, well it's late, I will work on that derivation tomorrow after some sleep. Thanks for the insight.
Thank you. I got it. The expression of E I needed is:
E = [R^2(24.0t^2 - 8.00t)]/(2r) where R is the radius of the circle and r is the radius of the electron's orbit.
