How Do You Solve a Second Order Linear Differential Equation?
captainjack2000
I have the equation -(ck^2)U(k,t)=d^2/dt U(k,t). And I need to find the general solution.
I can rearrange this into the form d^2 U/dt^2 + (ck^2)U(k,t)=0 but I am not sure of the form of the solution to this equation.
could someone please give me pointer in the right direction
Is it just U(k,t) = Acos(ckt)+Bcos(ckt)?
Yeah, it's just the differential equation for SHM so that is the solution.
No it's not. You will get a constant when you do the integration with respect to t, and this constant can depend on k. So the general solution is what you wrote + f(k), where f(k) is an arbitrary function of k.
EDIT: You should have (√c)k instead of ck in the sin and cos.
Oops! I'm extremely sorry, my previous post is wrong. The constants A and B are the constants of integration, and they should be arbitrary functions of k.
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
