FBD Help: Tension and Slowing Down
  • Thread starter Thread starter woodrufs
    Fbd
The discussion focuses on understanding the tension in a string when a ship is slowing down. The user expresses confusion about the relationship between tension and the ship's deceleration, questioning whether the string is fully stretched. A response clarifies that the forces acting on the instrument include its weight and the tension in the wire, emphasizing that tension always pulls away from the object. It is noted that since the ship is decelerating, the net force must align with the direction of acceleration. The user ultimately finds clarity and successfully resolves the issue with the help provided.
woodrufs
First of all, thank you for taking your time to look at this. I cannot seem to figure it out!
http://screencast.com/t/MzZiNjhmMzUt
I may be completely wrong, but I feel like there isn't any tension... If the ship is slowing down, doesn't that mean that the string isn't fully stretched out...? I'm so confused! :confused:
Thank you.
None? It's a FBD?
I'm sure this is extremely hard to see but here are my attempts. I've tried them both in the same direction and everything...
http://screencast.com/t/MmNkMzM3
Thanks again for everyone's help!
Draw the FBD of the instrument. You do note that the 2 forces acting on it are its weight and the tension force in the hanging wire. Since it is given that the acceleration is slowing down the rocket's (and instrument's) velocity, what direction must the acceleration be in?? Then use Newton 2, noting that the net force must be in the same direction of the acceleration. Note also that tension forces always pull away drom the object on which they act. Crunch out the numbers to get the relative scale of the weight and tension forces. (There will always be some tension in the rope, unless the object is in free fall, in which case the wire goes slack (no tension)).
Yay! Thanks Jay! That helped me out and I got it right!
Thank you!
You are welcome. Wecome to PF!
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
