FEA issue with workbench plus question on equation with conical shells
The discussion focuses on designing conical shells to analyze their impact on buckling load and natural frequency in launch vehicle adapters. A key issue raised is the confusion surrounding the "semi vertex angle of cone," which is defined as the angle between the centerline and the wall of the truncated cone. The user is struggling with transitioning from static structural analysis to linear buckling analysis in ANSYS Workbench, expressing frustration with the software's complexity. Suggestions include leveraging the existing static model to identify buckling points without reverting to a simpler analysis type. Overall, the conversation highlights the challenges of using advanced simulation software for structural analysis.
R.enR
Hi everybody,
I am designing conical shells in the aim to better understand the launch vehicle adapter and what changing thickness of conical shells will do to buckling load and natural frequency.
I have an issue with certain equations I have characteristic equations with a critical axial compression for truncated conical shells and buckling moment for a truncated cone along with several other equations. I have all the values except the "semi vertex angle of cone" what exactly is that as in where is that located in a truncated cone?
My main concern right now is with workbench and it is a new program that I am reall struggling to come to terms with. I have a symmetric model with a simple thin shelled design and it is merely me adding a load till the critical buckling load is identified. There bottom is fixed so there is no freedom of movement, I know this is very simple to model but for the life of me I can't seem to be able to go from static structural analysis to linear buckling analysis for the same model. I have duplicated the model and altered the analysis type it doesn't work I have attempted to start fresh with a linear buckling analysis but I cannot seem to find the buckling point of this model. It has "command" and initial environment as the different things I can input below the mesh section. If anyone has an idea of how to model could they tell me step by step because I must be an alien or mentally slow with this program right now but it is the bane of my existence currently :confused:
Any help would be really appreciated
Thank you
Since you already have a static non-linear model that shows the buckling, you wouldn't gain anything except speed by stepping back to the simpler linear buckling.
For static, you can get it to increase the load automatically, but I can't quite remember how :P Never done linear buckling in ANSYS tho sorry.
Yea don't worry that it's hard, people pay thousands for training courses on that, and still just skim the surface :P Just be grateful that you have Workbench, not Classic.
semi vertex angle would be the angle between the centerline and wall. i.e. half the angle at the (truncated away) vertex of the cone.
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
Thread 'What's the most likely cause for this carbon seal crack?'
We have a molded carbon graphite seal that is used in an inline axial piston, variable displacement hydraulic pump. One of our customers reported that, when using the “A” parts in the past, they only needed to replace them due to normal wear. However, after switching to our parts, the replacement cycle seems to be much shorter due to “broken” or “cracked” failures. This issue was identified after hydraulic fluid leakage was observed. According to their records, the same problem has occurred...
