Feedback Request Re U.S. Pat. 9,052,001
  • Thread starter Thread starter Cycloid Drive Cam
    Feedback Request
A newly patented device converts high-speed rotary motion into slow-speed, ultraprecise, high-force linear motion using a single compact part. The inventor seeks feedback on the invention's positives and negatives, particularly in relation to its target applications, which include autofocus lenses and any system requiring similar motion conversion. Key advantages include a speed reduction ratio of up to 100:1, torque multiplication of up to 100X, and the ability to produce high linear output forces while maintaining compactness. Suggestions for marketing include exploring specialized exhibitions to showcase the design and engage with potential companies. The discussion emphasizes the need for constructive feedback to enhance the marketing and licensing process.
Cycloid Drive Cam
I've recently patented a device which converts high speed rotary motion to slow speed, ultraprecise, high force linear motion using a single, compact moving part. I've just begun the marketing/licensing process but am having trouble getting any useful feedback. If you'd be so kind, please look at the details of my invention at the link below and advise me as to what you think the positives and negatives of my invention are.
Thank you!
Thank you!
Welcome to the PF.
What are the target applications that you designed this for? I see there is a slide in your presentation comparing it to a linear screw mechanism -- is the advantage of your mechanism a bigger divide-down ratio?
I originally conceived the idea while designing autofocus lenses but the device serves any application requiring conversion of high speed rotary input motion to high force, slow speed, short range linear output motion. I've listed all the advantages at 7:38 in the video but in summary they are speed reductions up to 100:1, torque multiplications up to 100X, very high linear output forces, compactness, easily manufactured single moving part, compactness and infinitely variable "pitches" (ie. for every input rotation any linear step distance desired within the total range of movement).
Maybe you can check if there are specialized exhibitions where you can show your design and talk to other companies about your product.
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
Thread 'What's the most likely cause for this carbon seal crack?'
We have a molded carbon graphite seal that is used in an inline axial piston, variable displacement hydraulic pump. One of our customers reported that, when using the “A” parts in the past, they only needed to replace them due to normal wear. However, after switching to our parts, the replacement cycle seems to be much shorter due to “broken” or “cracked” failures. This issue was identified after hydraulic fluid leakage was observed. According to their records, the same problem has occurred...
