Field lines from a line of charge
vikasagartha
I have a general gauss' law/electric field question.
In calculating the electric field of a cylindrical shape, gauss' law can be applied to find that the Electric field only points aways from the surface of the cylinder (aka, in the s-hat direction). But this means that there are no field lines directed along the cylinder...why isn't there a field line that points directly up or down along the z axis? For a finite cylinder, this would make sense to me. However, whenever you are calculating the E field via gauss' law, you neglect the surface area of the circles in the cylinder...can someone please clarify why this is? I have taken it for granted for a long time but never really understood...
Thanks in advance!
There are. But they get canceled out since two points on the conductor on either side of your point of consideration produce electric fields in opposite directions.
vikasagartha said:
..you neglect the surface area of the circles in the cylinder...can someone please clarify why this is?
Because there is no electric field passing through these circles. Reason same as above. Along the cylinder is nothing but perpendicular to these circles.
Gauss's law only helps if it is an infinitely long cylinder so that symmetry suggests there is no longitudinal E field.
Thread 'Colors in a plasma globe'
I have a common plasma globe with blue streamers and orange pads at both ends. The orange light is emitted by neon and the blue light is presumably emitted by argon and xenon. Why are the streamers blue while the pads at both ends are orange? A plasma globe's electric field is strong near the central electrode, decreasing with distance, so I would not expect the orange color at both ends.
  • · Replies 28 ·
  • · Replies 73 ·
  • · Replies 30 ·
  • · Replies 18 ·
