Field lines near the equilibrium point
The discussion focuses on calculating the electric potential θ(x,y) in the xy-plane due to two point charges, 4q and -q, located at (-2a,0,0) and (-a,0,0) respectively. The potential is expressed as θ(x,y) = (1/(sqrt((x-2)²+y²)) - (1/sqrt((x-1)²+y²)). The equilibrium point is confirmed to be at the origin, with emphasis on the need to account for the differing magnitudes of the charges. Participants suggest sketching the vectors and writing the potential equation along the x-axis for clarity.
  • Understanding of electric potential and Coulomb's law
  • Familiarity with Taylor series expansions
  • Basic knowledge of vector addition in physics
  • Ability to perform mathematical manipulations involving square roots
  • Study the concept of electric potential in electrostatics
  • Learn about Taylor series and their applications in physics
  • Explore vector addition techniques in two-dimensional space
  • Investigate the implications of charge magnitude and sign on electric fields
Students studying electromagnetism, physics educators, and anyone interested in understanding electric potential and equilibrium points in electrostatic systems.
scotshocker
Charges 4q and -q are located at the points (-2a,0,0) and (-a,0,0), respectively. Write down the potential θ(x,y) for points in the xy plane, and then use a Taylor expansion to find an approximate expression for θ near the origin, which you can quickly show is the equilibrium point. (You can set a=1 to make things simpler)
θ(x,y,s)=∫(ρ(x',y',z')dx'dy'dz')/4πεr
setting a-1, ignoring the factor of q/4πε0, the potential due to the two charges, at locations in the xy plane is θ(x,y)=(1/(sqrt((x-2)2+y2)-(1/sqrt((x-1)2+y2)
Have I set this equation up correctly?
Welcome to PF;
... how would you check?
i.e. is the equilibrium point at the origin as the problem says?
(Notice that one of the charges is much bigger than the other? Have you accounted for that?)
Have you checked that you have added the vectors properly - say, by sketching them out head-to-tail?
Hello, scotshocker. Welcome to PF!
Looks good except for a couple of signs. At what values of x would you expect the potential to be undefined?
[EDIT: And as Simon points out, the charges are not of equal magnitude.]
The fact that the one charge is larger than the other is the part that I am having trouble with. I am also confusing myself because both charges are on the same side of the origin. I am severely out of practice and am just trying to figure this out. Any suggestions?
The charges are also opposite signs.
Perhaps you'd better write down the equation for the potential along just the x-axis to start with - don't leave off the q and the a this time: I think you removed them too soon, before you understood the situation.
Once you see that, you'll probably make the connections you need.
Actually draw the axes - mark out x=0, x=+a, x=+2a, x=-a, x=-2a, etc.
  • · Replies 17 ·
  • · Replies 69 ·
  • · Replies 19 ·
