Final charge on capacitor for an RC circuit
The discussion focuses on the final charge of a capacitor in an RC circuit, specifically addressing the equation q = CE(1 - e^{-t/RC}). Participants clarify that this equation only holds true when the capacitor is directly connected to the voltage source, while in this case, it is connected to resistor R2. They confirm that the voltages across the capacitor and R2 are equal since they are in parallel, but emphasize that current does not flow through the capacitor in a steady state, effectively making it an open circuit. The conversation concludes with a realization that the initial confusion stemmed from misapplying current equations relevant to series circuits. Understanding the circuit's configuration is crucial for correctly analyzing the capacitor's behavior.
unseeingdog
##q = CE(1 - e^{-t/RC})##
I assumed that, since the problem specifies that sufficient time has passed, it meant to say that enough time passed. thus making the exponential term in the equation go down to 0, and the charge in the capacitor simply ##CE##, but the book says the answer is (f), and I don't have any idea how.
P.S: Sorry for the title, I accidentally wrote "Optics", and now it seems I can't change it.
There's no problem statement, and your image is essentially empty.
Likes unseeingdog
Sorry, I'm trying to fix it. Something went wrong with the attachment
The equation is not true if the capacitor is not connected directly to the source.
The capacitor is connected to the resistor R2. How is the capacitor voltage related to the voltage across R2?
Likes unseeingdog
I've fixed your title for you :smile:
Likes unseeingdog
Oh, great! Thanks.
Are they equal? Wouldn't the voltage in ##R_2## eventually drop to 0 because of the current going down, or does that equation for the current also not apply?
Yes, the voltages are equal as the capacitor and R2 are connected parallel. But why do you think that the current is zero through R2? The source, the two resistors and the switch make a closed loop. Current will flow forever through the resistors.
Likes unseeingdog
I thought so because of the equation for the current, namely ##i =\left(\frac E R \right) (e^{-t/RC})##, but I suppose that one doesn't apply either, since it's derived from the other one I mentioned.
Nevermind. It was a million times easier than I thought. I just had to do ##iR_2 = \frac q C##, ##i## being ##\ \frac {E}{R_1 + R_2}##. Thanks for the help.
Likes scottdave
unseeingdog said:
Nevermind. It was a million times easier than I thought. I just had to do ##iR_2 = \frac q C##, ##i## being ##\left (\frac {E}{R_1 + R_2} \right)##. Thanks for the help.
Correct, as no current flows through the capacitor in stationary state, after the switch is closed for a long time.
Likes unseeingdog
That would be if a capacitor and resistor are in series with a voltage source. Think about this: when a capacitor has no current flowing through it, it essentially acts as an open circuit. So what is the voltage across R2 if the capacitor is just an open circuit?
Likes unseeingdog
