Displacement -0.25i + 14.7j from Origin: Final Displacement
  • Thread starter Thread starter Austin Gibson
    Displacement Final
The cyclist's journey involves riding 3.0 km west, then 16.0 km at 23° west of north, followed by 9.0 km east. The final displacement is calculated in vector form, resulting in -0.25i + 14.7j km. An initial answer of -0.26i was rejected, but adjusting it to -0.25i was accepted. The discussion highlights the frustration with the answer validation criteria. Overall, the correct final displacement from the origin is confirmed as -0.25i + 14.73j km.
Austin Gibson
1. A cyclist rides 3.0 km due west, then 16.0 km 23° west of north. From this point she rides 9.0 km due east. What is the final displacement from where the cyclist started (in km)? (Express your answer in vector form. Assume the +x-axis is to the east, and the +y-axis is to the north.)
Picture of question: https://gyazo.com/31eff7abeed1f8ef80293518c12f183b
2. Displacement = r final - r initial3. I converted the cardinal coordinates to (3, 180 degrees), (16, 113 degrees), and (9,0 degrees). The total of the vectors in vector form is -0.25i + 14.7j. That's the displacement if the origin is (0,0) by my estimation, but that answer was rejected. What am I missing?
Try 14.73 for the ##\hat{j}## component. Otherwise I get the same answers.
Likes Austin Gibson
Your answer looks good to me.
Likes Austin Gibson
Thank you for your reply. Apparently, I entered -0.26i as my initial answer and it rejected that. Usually if the answer is close, it accepts it. Their criteria for solutions is frustrating.
As I mentioned to verty, after I increased -0.26i to -0.25i, it accepted by answer. I wasted an hour of my life on one question. :sorry:
