Final temperature of two mixed substances (simply enthelpy math)
The discussion revolves around calculating the final temperature of a mixture of copper and water using the principle of heat transfer. The equation used is Q = m * ΔT * c, where heat lost by copper equals heat gained by water. The initial calculations led to an incorrect final temperature of 19.725°C, which is lower than both initial temperatures. The error identified is the assumption that the final temperature of copper could exceed its initial temperature of 100°C. The correct final temperature, as indicated, should be 29.6°C.
Esoremada
A 100-g sample of Cu(s), initially at 100oC, is added to 140 g of water, initially at 25oC. What is the final temperature of the mixture?
Specific heat
(in J g-1 oC-1)
Cu(s) 0.385
H2O(l ) 4.184
Q = m * ΔT * c
heat lost = heat gained
= m2 * ΔT2 * c2
100 * (T2 - 100) * 0.385 = 140 * (T2 - 25) * 4.185
38.5* (T2 - 100) = 585.9 * (T2 - 25)
38.5T2 - 3850 = 585.9T2 - 14647.5
T2 = 19.725°CBut the temperature can't be lower than both their starting temperatures, what did I do wrong? The answer is supposed to be 29.6
From the way you have written your equation, you are assuming that the final temperature T2 of the copper is greater than 100 C.
Thread 'Confusion regarding a chemical kinetics problem'
TL;DR Summary: cannot find out error in solution proposed. [![question with rate laws][1]][1] Now the rate law for the reaction (i.e reaction rate) can be written as: $$ R= k[N_2O_5] $$ my main question is, WHAT is this reaction equal to? what I mean here is, whether $$k[N_2O_5]= -d[N_2O_5]/dt$$ or is it $$k[N_2O_5]= -1/2 \frac{d}{dt} [N_2O_5] $$ ? The latter seems to be more apt, as the reaction rate must be -1/2 (disappearance rate of N2O5), which adheres to the stoichiometry of the...
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
