Find Polynomial of Degree <2 to Satisfy (1, p), (2, q), (3, r)
  • Thread starter Thread starter VinnyCee
    Degree Polynomial
VinnyCee
Find a polynomial of degree < 2 [a polynomial of the form f\left(t\right)\,=\,a\,+\,bt\,+\,ct^2] whose graph goes through the points (1, p), (2, q), (3, r), where p, q, r are arbitrary constants. Does such a polynomial exist for all values of p, q, r?
Here is what I have so far:
(1, p) ==> p\,=\,a\,+\,b\,+\,c
(2, q) ==> q\,=\,a\,+\,2b\,+\,4c
(3, r) ==> r\,=\,a\,+\,3b\,+\,9c
\begin{displaymath}<br /> \left[ \begin{array}{ccc|c}<br /> 1 &amp; 1 &amp; 1 &amp; p \\<br /> 1 &amp; 2 &amp; 4 &amp; q \\<br /> 1 &amp; 3 &amp; 9 &amp; r<br /> \end{array} \right]<br /> \end{displaymath}
R_2\,=\,R_2\,-\,R_1
R_3\,=\,R_3\,-\,R_1
\begin{displaymath}<br /> \left[ \begin{array}{ccc|c}<br /> 1 &amp; 1 &amp; 1 &amp; p \\<br /> 0 &amp; 1 &amp; 3 &amp; q - p \\<br /> 0 &amp; 2 &amp; 8 &amp; r - p<br /> \end{array} \right]<br /> \end{displaymath}
R_3\,=\,R_3\,-\,2R_2
\begin{displaymath}<br /> \left[ \begin{array}{ccc|c}<br /> 1 &amp; 1 &amp; 1 &amp; p \\<br /> 0 &amp; 1 &amp; 3 &amp; q - p \\<br /> 0 &amp; 0 &amp; 2 &amp; r - q<br /> \end{array} \right]<br /> \end{displaymath}
R_3\,=\frac{1}{2}\,R_3
\begin{displaymath}<br /> \left[ \begin{array}{ccc|c}<br /> 1 &amp; 1 &amp; 1 &amp; p \\<br /> 0 &amp; 1 &amp; 3 &amp; q - p \\<br /> 0 &amp; 0 &amp; 1 &amp; \frac{1}{2}\left(r - q\right)<br /> \end{array} \right]<br /> \end{displaymath}
R_2\,=\,R_2\,-\,3R_3
\begin{displaymath}<br /> \left[ \begin{array}{ccc|c}<br /> 1 &amp; 1 &amp; 1 &amp; p \\<br /> 0 &amp; 1 &amp; 0 &amp; \frac{5}{2}\,q\,-\,p\,-\,\frac{3}{2}\,r \\<br /> 0 &amp; 0 &amp; 1 &amp; \frac{1}{2}\left(r - q\right)<br /> \end{array} \right]<br /> \end{displaymath}
R_1\,=\,R_1\,-\,R_2\,-\,R_3
\begin{displaymath}<br /> \left[ \begin{array}{ccc|c}<br /> 1 &amp; 0 &amp; 0 &amp; 2p\,-\,2q\,+\,r \\<br /> 0 &amp; 1 &amp; 0 &amp; \frac{1}{2}\left(5q\,-\,2p\,-\,3r\right) \\<br /> 0 &amp; 0 &amp; 1 &amp; \frac{1}{2}\left(r - q\right)<br /> \end{array} \right]<br /> \end{displaymath}
a\,=\,2p\,-\,2q\,+\,r
b\,=\,\frac{1}{2}\,\left(5q\,-\,2p\,-\,3r\right)
c\,=\,\frac{1}{2}\,\left(r\,-\,q\right)
f\left(t\right)\,=\,\left(2p\,-\,2q\,+\,r\right)\,+\,\left[\frac{1}{2}\,\left(5q\,-\,2p\,-\,3r\right)\right]\,t\,+\,\left[\frac{1}{2}\,\left(r\,-\,q\right)\right]\,t^2
f\left(t\right)\,=\frac{1}{2}\,r\,t^2\,-\,\frac{1}{2}\,q\,t^2\,+\,\frac{5}{2}\,q\,t\,-\,\frac{3}{2}\,r\,t\,-\,p\,t\,+\,2\,p\,+\,r\,-\,2\,q
But when I try a set of arbitrary numbers [(1, 8), (2, 12), (3, 3)], I get an equation that does not match the points:
f\left(t\right)\,=\,-\frac{9}{2}\,t^2\,+\,\frac{35}{2}\,t\,-\,5
f\left(1\right)\,=\,-\frac{9}{2}\,(1)^2\,+\,\frac{35}{2}\,(1)\,-\,5\,=\,8
f\left(2\right)\,=\,-\frac{9}{2}\,(2)^2\,+\,\frac{35}{2}\,(2)\,-\,5\,=\,12
f\left(3\right)\,=\,-\frac{9}{2}\,(3)^2\,+\,\frac{35}{2}\,(3)\,-\,5\,=\,7
However, f\left(3\right) should be equal to r, which is 3, not 7.
Please help:)
VinnyCee said:
Find a polynomial of degree < 2 [a polynomial of the form ] whose graph goes through the points (1, p), (2, q), (3, r), where p, q, r are arbitrary constants. Does such a polynomial exist for all values of p, q, r?
Of degree < 2? Then it is linear, of the form y= mx+ b and you can only determine only the two numberss m and b. In general 2 equations will do that. You can choose m and b so that 2 of the requirements (1, p), (2, q), (3, r) are satisfied but not all 3.
For (p, q, r) = (0, 0, 0) we have (a, b, c) = (0, 0, 0), and therefore a zero polynomial, which has a degree undefined or -\infty, so it's less than 2. :biggrin:
The title says "Find a >2 degree polynomial" and the post itself says
"Find a polynomial of degree < 2".
Is it any wonder I'm confused!
Confusion about <2 vs >2 aside, your derivation has an error in the quoted section. You substract 2 R_2 from R_3, but in the augmented part of the matrix you've only subtracted 1 R_2, resulting in r - q instead of r + p - 2q. I didn't check to see if everything else was correct, but this is certainly a place to start with.
Sorry for the confusion!
The polynomial needs to have a degree of GREATER THAN OR EQUAL TO 2.
So it needs to have at least one squared term.
Here is the corrected derivation with help from Mute (Thanks!):
R_2\,=\,R_2\,-\,R_1
R_3\,=\,R_3\,-\,R_1
\begin{displaymath}<br /> \left[ \begin{array}{ccc|c}<br /> 1 &amp; 1 &amp; 1 &amp; p \\<br /> 0 &amp; 1 &amp; 3 &amp; q - p \\<br /> 0 &amp; 0 &amp; 2 &amp; r - 2q + p<br /> \end{array} \right]<br /> \end{displaymath}
\begin{displaymath}<br /> \left[ \begin{array}{ccc|c}<br /> 1 &amp; 1 &amp; 1 &amp; p \\<br /> 0 &amp; 1 &amp; 3 &amp; q - p \\<br /> 0 &amp; 0 &amp; 1 &amp; \frac{1}{2} r - q + \frac{1}{2} p<br /> \end{array} \right]<br /> \end{displaymath}
\begin{displaymath}<br /> \left[ \begin{array}{ccc|c}<br /> 1 &amp; 1 &amp; 1 &amp; p \\<br /> 0 &amp; 1 &amp; 0 &amp; -\frac{5}{2}\,p\,+\,4\,q\,-\,\frac{3}{2}\,r \\<br /> 0 &amp; 0 &amp; 1 &amp; \frac{1}{2} r - q + \frac{1}{2} p<br /> \end{array} \right]<br /> \end{displaymath}
\begin{displaymath}<br /> \left[ \begin{array}{ccc|c}<br /> 1 &amp; 0 &amp; 0 &amp; 3\,p\,-\,3\,q\,+\,r \\<br /> 0 &amp; 1 &amp; 0 &amp; -\frac{5}{2}\,p\,+\,4\,q\,-\,\frac{3}{2}\,r \\<br /> 0 &amp; 0 &amp; 1 &amp; \frac{1}{2} r - q + \frac{1}{2} p<br /> \end{array} \right]<br /> \end{displaymath}
a\,=\,3\,p\,-\,3\,q\,+\,r
b\,=\,-\frac{5}{2}\,p\,+\,4\,q\,-\,\frac{3}{2}\,r
c\,=\,\frac{1}{2} r - q + \frac{1}{2} p
f\left(t\right)\,=\,\left(3\,p\,-\,3\,q\,+\,r\right)\,+\,\left[-\frac{5}{2}\,p\,+\,4\,q\,-\,\frac{3}{2}\,r\right]\,t\,+\,\left[\frac{1}{2} r - q + \frac{1}{2} p\right]\,t^2
f\left(t\right)\,=\frac{1}{2}\,r\,t^2\,+\,\frac{1}{2}\,p\,t^2\,-\,q\,t^2\,+\,4\,q\,t\,-\,\frac{5}{2}\,p\,t\,-\,\frac{3}{2}\,r\,t\,+\,3\,p\,+\,r\,-\,3\,q
p\,=\,8
q\,=\,12
r\,=\,3
So now it works for these numbers!
f\,(\,t\,)\,=\,-\frac{13}{2}\,t^2\,+\,\frac{47}{2}\,t\,-\,9
f\,(\,1\,)\,=\,-\frac{13}{2}\,(\,1\,)^2\,+\,\frac{47}{2}\,(\,1\,)\,-\,9\,=\,8
f\,(\,2\,)\,=\,-\frac{13}{2}\,(\,2\,)^2\,+\,\frac{47}{2}\,(\,2\,)\,-\,9\,=\,12
f\,(\,3\,)\,=\,-\frac{13}{2}\,(\,3\,)^2\,+\,\frac{47}{2}\,(\,3\,)\,-\,9\,=\,3
But how can I figure (or prove) whether or not a polynomial exists for all values of p, q, and r? There does exist such a polynomial for all p, q, and r right?
