Find (AB)^-1 with Given Matrices | Inverse of 2x2 Matrices
  • Thread starter Thread starter Ownaginatious
    Inverse Matrix
The discussion centers on finding the inverse of the product of two 2x2 matrices, A and B, using the formula (AB)^{-1} = B^{-1}A^{-1}. A participant presents their calculated result for (AB)^{-1} but finds a discrepancy with the textbook answer. Clarifications reveal that if a specific entry in B^{-1} is corrected, the textbook answer aligns with the participant's calculations. Additionally, some participants suggest that calculating AB first before finding the inverse may be a more straightforward approach. The conversation highlights the importance of accuracy in matrix entries and the potential for typos in textbooks.
Ownaginatious
Use the given matrices to find (AB)^-1
(These are 2 X 2 matrices, please ignore the fraction bar in between the top and bottom elements. I can't figure this stupid latex piece of crap out)
A^{-1} = \left(\frac{\frac{1}{2}}{\frac{-1}{2}} \ldots \frac{\frac{-5}{2}}{\frac{3}{2}}\right)
B^{-1} = \left(\frac{\frac{2}{3}}{\frac{-1}{3}} \ldots \frac{\frac{4}{3}}{\frac{5}{2}}\right)
Only the one for inverse matrices which states,
The answer I get in the end is:
(AB)^{-1} = \left(\frac{\frac{-1}{3}}{\frac{-17}{12}} \ldots \frac{\frac{1}{3}}{\frac{55}{12}}\right)
But the book gets,
(AB)^{-1} = \left(\frac{\frac{-1}{3}}{-1} \ldots \frac{\frac{1}{3}}{\frac{10}{3}}\right)
Am I the one doing something wrong, or is the book wrong?
Any help would be greatly appreciated.
Thanks!
If you copied the matrices correctly, your answer is correct.
If the 5/2 in (2,2)-entry of B^{-1} is supposed to be 5/3 then the book is correct.
By the way, click the formula to see the LaTeX code:
<br /> A^{-1} = \begin{pmatrix} \frac{1}{2} &amp; -\frac52 \\ \-\frac{1}{2} &amp; \frac{3}{2} \end{pmatrix} = <br /> \frac12 \begin{pmatrix} <br /> 1 &amp; -5 \\ <br /> -1 &amp; 3<br /> \end{pmatrix}<br />
Nope, the book says what I wrote. I'm not surprised though; I've found several typos in the questions in this particular textbook...
Thanks a lot for the clarification, I thought maybe I was missing some obscure rule :p.
Also, thanks for showing how to use the LaTex code properly :)
Ownaginatious;2156299[h2 said:
Homework Equations[/h2]
I find it a lot more easy to calculate AB first,then the inverse...
just a tip,since the main question was already answered
In this case your approach would take longer, because you first have to calculate A and B from their inverses, then multiply them and finally take the inverse of that, while just multiplying the two given matrices in the correct order gives you the right answer immediately.
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
