Find all Complex 2x2 matrices A
  • Thread starter Thread starter beetle2
    Complex Matrices
beetle2
Find all Complex 2x2 matrices A such that A2 = A
<br /> \[ \left( \begin{array}{cc}<br /> a &amp; b \\<br /> c &amp; d \\ \end{array} \right)^2\] = A<br /> <br />
A2=A
I need to solve the equations
<br /> a^2+bc=a<br />
<br /> <br /> (a+d)b =b<br />
<br /> <br /> (a+d)c = c\\<br />
<br /> <br /> d^2 + bc = d\\<br />
What is the best way to do this?
Should I use some kind of rearrangement like
using equation 1 and 4 we get
<br /> a^2-d^2=a-d
any help greatly appreciated
I would think about two cases, that where A-1 exists and where it doesn't exist.
Are you talking about when A is an orthogonal matrix so A-1 = AT?
The question is: Is A invertible? If so, then just take A-1 of both sides and what do you get?
A-1 exist when ad-cb \neq 0
so
case 1 ad-cb \neq 0
case 2 ad-cb = 0
Stop looking at the series of equations you have
If
A2=A
And A-1 exists
In one step you can find A
If A is invertable and A2=A
AA=A
A-1AA=A-1A
IA=I
So A = I
Now if A is not invertible, what can you say about how A acts on im(A), its image?
Think about the fact that if A^2= A then A^2- A= A(A- I)= 0
Would that mean that the only way that
A^2- A= A(A- I)= 0
is that either A = the trivial solution.
\[ \left( \begin{array}{cc}0 &amp; 0 \\0 &amp; 0 \\ \end{array} \right)\] = A
or
\[ \left( \begin{array}{cc}-1 &amp; 0 \\0 &amp; -1 \\ \end{array} \right)\] = A
regards
A^2- A= A(A- I)= 0
or
regards
That's completely wrong thinking. If A and B are matrices AB=0 does NOT mean A=0 or B=0. And [[-1,0],[0,-1]] doesn't work at all. Here's some other ones that do [[1,0],[0,0]], [[1,1],[0,0]], [[1/2,1/2],[1/2,1/2]]. There's LOTS of them. You already followed up on the excellent hint that if A is invertible, then A=I is the only solution. Now suppose A is not invertible. Then det(A)=0, so you can add the condition ad-bc=0 to your original list of equations. That makes it easier. Now go to those equations and start working on cases. You should be able to write down a two parameter family of solutions that satisfy A^2=A besides the zero matrix.
For the record, responders have been suggesting two different methods of approach. Office_Shredder's is a geometric one, and offers more insight into why idempotent matrices are interesting. The other was more algebraic.
I confess I would have suggested yet a different approach, one that starts by looking at the equation (a+d)b=b.
Why is that different from the algebraic approach? I'm just saying that the equations the OP originally posted are a lot easier to solve if you restrict to the case of noninvertible matrices, in which case you can put ad=bc. LCKurtz already suggested this, and it's a very good suggestion.
As idempotent matrices must eigenvalues of 1 and 0 would it be all the Matrices that can produce the diagonal matrix
\[ \left( \begin{array}{cc}1 &amp; 0 \\0 &amp; \\ \end{array} \right)\] = A
No, I already pointed out that [[1/2,1/2],[1/2,1/2]] works.
beetle2 said:
As idempotent matrices must eigenvalues of 1 and 0...
Figures you'd go for yet another solution! There are (at least) three things you need to do to turn this into a complete solution and a proof.
(1) What about non-diagonalizable matrices?
(2) For the diagonalizable solutions, you haven't covered all possible diagonal forms.
(3) You still need to simplify your characterization of the solutions into a form that would be considered "found".
So I have the first case where the matreix is invertable
If A is invertable and A^2=A
AA=A
A-1AA=A-1A
IA=I
So A = I
The other case is when A is not invertable so then the det(A) = 0
A^2 = A
AA = A
AA - A = A - A
AA - A = 0
A(I-A) = 0
SO what complex matrix will do this?
AA=A
A-1AA=A-1A
IA=I
So A = I
A^2 = A
AA = A
AA - A = A - A
AA - A = 0
A(I-A) = 0
I already told you in post 10 that that factorization isn't particularly useful. Go back to your original set of equation and add the condition det(A)=0=ad-bc. You'll find they are pretty easy to solve.
For det(A)= 1 = invertable
\[ \left( \begin{array}{cc}1 &amp; 0 \\0 &amp; 1 \\ \end{array} \right)\]
for det(A) = 0 = non invertable
b or c can be any value
\[ \left( \begin{array}{cc}1 &amp; b \\0 &amp; 0 \\ \end{array} \right)\]
\[ \left( \begin{array}{cc}1 &amp; 0 \\c &amp; 0 \\ \end{array} \right)\]
\[ \left( \begin{array}{cc}0 &amp; b \\0 &amp; 1 \\ \end{array} \right)\]
\[ \left( \begin{array}{cc}0 &amp; 0 \\c &amp; 0 \\ \end{array} \right)\]
also you have
for all square matrices nXn
\[ \left( \begin{array}{cc}\frac{1}{n} &amp; \frac{1}{n} \\\frac{1}{n} &amp; \frac{1}{n} \\ \end{array} \right)\]
I'm not sure how to get that last one. I just noticed that DIck posted that one and by trying different options noticed that it worked for all nXn matrices
Those are all one parameter special cases. At least the ones that actually work are. The really general solution has two free parameters b and c, both in the same matrix. Can you find it? It includes the [[1/2,1/2],[1/2,1/2]] case. I keep telling you to go back to your original equations and add ad=bc.
I start out with.
a^2+bc=a
(a+d)b=b
(a+d)c=c
d^2+bc=d
I set them all to equal zero.
a^{2}-a+bc=0(1)
(a+d-1)b=0(2)
(a+d-1)c=c(3)
d^{2}-d+bc=0(4)]
and
ad-bc=0(5)
From equation (2) either a+d=1 or b=0
So take b\neq 0 \rightarrow a+d=1 than (3) and (2) are both satisfied.
from (1) c=\frac{a-a^2}{b} since b\neq 0[
for d we can use from a+d=1 we have d = 1-a
So using (4) = (1-a)^2-(1-a)+((a+1-a)\times(\frac{a-a^2}{b}))
= (1-a)^2-(1-a)+((a-a^2)
=-a+a^2+a-a^2=0
So for b neq 0 we have the general matrix
\[ \left( \begin{array}{cc}a &amp; b \\\frac{a-a^2}{b} &amp; 1-a \\ \end{array} \right)\]
I'm sure there is an easier way to do this
beetle2 said:
I start out with.
a^2+bc=a
(a+d)b=b
(a+d)c=c
d^2+bc=d
a^{2}-a+bc=0(1)
(a+d-1)b=0(2)
(a+d-1)c=c(3)
d^{2}-d+bc=0(4)]
and
ad-bc=0(5)
=-a+a^2+a-a^2=0
You've got it. Yes. Was that really so hard? a=1/2 and b=1/2 gives you the [[1/2,1/2],[1/2,1/2]] solution. And now you can find a lot more solutions where none of the matrix entries are zero. Like M=[[2,3],[-2/3,-1]]. M.M=M. That's a=2, b=3. That's exactly what I was looking for.
