Find angular velocity using angular momentum
To find the new angular velocity after the girl walks inward on the turntable, conservation of angular momentum is applied, resulting in a final angular velocity of 1.37 rad/s. The change in kinetic energy can be calculated using the initial and final kinetic energies based on the moment of inertia and angular velocities. For part c, the total angular momentum of the girl and turntable system is conserved, allowing the calculation of the turntable's angular velocity when the girl walks at 2 m/s relative to the ground. In part d, the same principle applies, but the girl’s speed is relative to the turntable, necessitating a different approach to find the turntable's angular velocity. The discussion emphasizes the importance of treating the girl and turntable as separate entities while conserving angular momentum.
vu10758
A 20kg girl stands on a large turntable 4m from its center. The turntable has a moment of inertia (about its roation axis) of 200kgm^2. Assume that the girl is a point mass.
a) Assume that the girl and turntable are rotating at 1 rad/s. If the girl walks inwards to a radius of 3m and stops, what is the new angular velocity?
b) Find the change in kinetic energy.
I got these two parts, but I am stuck with c and d
c) Assume that the turnable is initially stationary and the girl is at r=4m.
The girl starts walking in a circle around the turntable at a speed of 2m/s relative to the ground. Find the angular velocity of the turntable relative to the ground.
d) The girl starts walking in a circle around the turntable at a speed of 2m/sy relative to the turntable. Find the angular velocity of the turntable relative to the ground.
c) I got from part a that w_i = 1 rad/s and w_f 1.37 rad/s. I know that that I = 200 + mr^2
However, I have no idea what to do when she walks 2m/s. As she gets closer to the center, the turntable will spin faster. But I don't know what to do for c and d.
For c and d the girl is no longer rotating at the same rate as the table. Don't try to find a moment of inertia for the system. Treat the girl as one object and the table as a second object and think about their individual angular momenta. The total angular momentum of the girl/table system is conserved. This is directly analogous to a linear momentum problem of a person walking on a plank that is on a frictionless surface. Starting from rest, if one thing goes one way, the other thing goes the other way.
For part c, you know the inital momentum is zero, that will be conserved. Set the angular momentum of the girl equal to the angular momentum of the turntable.
Edit: Wow, Dan you are all over the place.
Thank you.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
