Convergence of Series: Is There Only One Way to Solve This?
In summary, this conversation discusses the convergence of the series \sum_{n=0}^{\infty}\frac{1}{n^2+3n+2} and the methods used to determine its convergence. The comparison test is explored, as well as the use of partial fractions and the integral test. Ultimately, it is determined that the series converges to 1, although there is some discussion about the correctness of this conclusion.
DryRun
[tex]\sum_{n=0}^{\infty}\frac{1}{n^2+3n+2}[/tex]
The attempt at a solution
I'm wondering if there is only one way of solving this?
Here is what I've done: First, converting into partial fractions. Is there a way to do it without converting to partial fractions?
[tex]\sum_{n=0}^{\infty}\frac{1}{n^2+3n+2}=\sum_{n=0}^{\infty}\frac{-1}{n+2}+\sum_{n=0}^{\infty}\frac{1}{n+1}[/tex]
[tex](u1)_n=\frac{-1}{n+2}[/tex]Then, for large n,[tex](v1)_n=\frac{-1}{n}
\\(u2)_n=\frac{1}{n+1}[/tex]Then, for large n,[tex](v2)_n=\frac{1}{n}[/tex]
Initially, i decided to use the comparison test, but it failed (somewhat). Maybe i did it wrong?
Considering [itex]\sum_{n=0}^{ \infty}\frac{-1}{n+2}[/itex]: if i ignore the negative sign, then [itex]0<(u1)_n\leq (v1)_n[/itex]. But [itex](v1)_n[/itex] diverges, so the test does not apply in this case.
Now, if i were to consider the negative sign and put [itex](u1)_n[/itex] and [itex](v1)_n[/itex] on a number line, then i can see that [itex]0<(v1)_n\leq (u1)_n[/itex], in which case, the comparison test works and the series diverges. But this is an awkward conclusion in my opinion. So, which of these methods is the correct one?
Considering [itex]\sum_{n=0}^{\infty}\frac{1}{n+1}[/itex]: [itex]0<(u2)_n\leq (v2)_n[/itex], so the comparison test fails since [itex](v2)_n[/itex] diverges.
So, i opted for the limit comparison test and both of the sum series diverge, therefore the original series also diverges. It's unusual, as the comparison test failed, yet the limit comparison test agrees?
If what I've done above is correct, then i don't understand why this question is set before the comparison test is even introduced in my book. In fact, this problem is right after the geometric series, so i should probably use the latter to solve for this problem, but i can't figure out how to do it.
hi sharks! :smile:
hint: what is [itex]\sum_{n=0}^{N}\frac{-1}{n+2}+\sum_{n=0}^{N}\frac{1}{n+1}[/itex] ? :wink:
Using the Integral test? But that method has been introduced much later in the book, after this problem. So, i think i should solve it using geometric series or just apply the theorems that i use for sequences (although that would be incorrect, i think):
[tex]\sum_{n=0}^{ \infty}\frac{-1}{n+2}+\sum_{n=0}^{\infty}\frac{1}{n+1}=0[/tex]
As n approaches infinity, the values of each of these sums become 0. But I'm not sure about this, since I'm using a sequence theorem to solve series.
If we say [tex] n^2 < n^2+3n+2 [/tex]
So
[tex] \frac{1}{n^2} > \frac{1}{n^2+3n+2} [/tex] and
[tex] \sum \frac{1}{n^2} [/tex] converges so by the comparison test it converges ?
Would that be wrong ?PS: NOT GIVING A SOLUTION HE SAID HE TRIED THIS SO I JUST WANT TO SEE IF MY WORKING IS OKAY
So
Well, your reasoning would work; according to the comparison test, it would converge, but then you haven't expressed the expression in terms of partial fractions. I think for this type of problem, you must break it down into partial fractions before trying any test.
Is there a particular reason why you want to use partial fractions ? Seems like they would complicate things unnecessarily ?
That's what i would do if i were to integrate that expression, and since i should be able to use the Integral test, i think that's the way to go. However, I'm not even supposed to be using the Comparison or Integral Test, as it's not introduced in the book yet, since this problem is at the beginning of the chapter.
If it was a geometric series, then i could have found the limit.
OK, so if i factorize n from the denominator and numerator and then take the limit:
[tex]\sum_{n=0}^{N}\frac{-1}{n+2}+\sum_{n=0}^{N}\frac{1}{n+1}=\lim_{n \to \infty}\frac{-1/n}{1+2/n}+\lim_{n \to \infty}\frac{1/n}{1+1/n}=0+0=0[/tex] Is that correct?
Was it necessary to find the partial fractions? And what if i had a quadratic in the denominator, that was not factorisable?
what is -(1/3 + 1/4 + … 1/11 + 1/12) + (1/2 + 1/3 + … + 1/10 + 1/11) ? :wink:
[tex]\frac{1}{2}-\frac{1}{12}[/tex]
Ah yes, i see your point...
[tex]\sum_{n=0}^{\infty}\frac{1}{n^2+3n+2}=\sum_{n=0}^{ \infty}\frac{-1}{n+2}+\sum_{n=0}^{\infty}\frac{1}{n+1}=\sum^{ \infty }_{n=0} \left(1-\frac{1}{n+2}\right)[/tex]
[tex]\sum^{ \infty }_{n=0} \left(1-\frac{1}{n+2}\right)=\sum^{ \infty }_{n=0} 1-\sum^{ \infty }_{n=0} \left(\frac{1}{n+2}\right)=1-\sum^{ \infty }_{n=0} \left(\frac{1}{n+2}\right)[/tex] Then, i don't know. I'm back to the fraction form.
That argument is fine to prove the series converges, but by using partial fraction, you can also figure out what the series converges to.
sharks said:
[tex]\sum_{n=0}^{ \infty}\frac{-1}{n+2}+\sum_{n=0}^{\infty}\frac{1}{n+1}=\sum^{ \infty }_{n=0} \left(1-\frac{1}{n+2}\right)[/tex]
nooo :wink:
leave out a ∑ :smile:
Oh! You are correct.
[tex]\sum_{n=0}^{\infty}\frac{1}{n^2+3n+2}=\sum_{n=0}^{ \infty}\frac{-1}{n+2}+\sum_{n=0}^{\infty}\frac{1}{n+1}=\left(1-\frac{1}{n+2}\right)[/tex]
So, i guess that's the finally answer? Or do i need to replace n with ∞, thereby getting the final answer=1?
That's not correct. You can't actually break it into two series like that. What you can say is that
$$\frac{1}{n^2+3n+2} = \frac{1}{n+1}-\frac{1}{n+2}$$ (note there are no summations in what I just wrote) so that
$$\sum_{n=0}^\infty \frac{1}{n^2+3n+2} = \sum_{n=0}^\infty \left(\frac{1}{n+1}-\frac{1}{n+2}\right)$$ You can't break the righthand side into the difference of two summations because neither ##\displaystyle \sum_{n=0}^\infty \frac{1}{n+1}## nor ##\displaystyle\sum_{n=0}^\infty \frac{1}{n+2}## converges.
Take a look back to post #2 and note that Tiny Tim used N for the upper limit, not ∞. In that case, you have sums of finite number of terms, so you can break up the original sum into two separate sums. Specifically, that's the partial sum sN, whose limit as N goes to infinity is what the series, by definition, converges to. What is the partial sum sN equal to?
yup! :biggrin:
(btw, this is quite a common technique in exam problems …
you need to be familiar with it, and to look out for it! :wink:)​
[tex]S_N=\left(1-\frac{1}{n+2}\right)?[/tex]
Honestly, i think I'm in big trouble with differentiating between series and sequences, and how to figure them out without incorrectly mixing different techniques and theorems. It's not so obvious to me. Like mixing two types of noodles. I'll need to go over the Infinite Series chapter again.
The little n should be a capital N on the righthand side, but otherwise it's correct. You can see the limit of the sequence sN is 1, so the series converges to 1.
It's a bit confusing because there are two sequences associated with a series. First, there's the sequence an that make up the terms of the series. This sequence has to converge to 0 for the series to converge. Second, there's the sequence sn of partial sums. When you say an infinite series converges, it means the sequence of partial sum converges.
Thank you, vela. That helped a lot. I wonder why my books don't summarize it that way at the end of the chapter.:rolleyes:
But, what if an does not converge to 0? Suppose an converges to 1. Then, what conclusions can be drawn?
Edit: OK, i think i finally understand. If an does not converge to 0, then according to nth term test for divergence, the series is guaranteed to diverge.
See if your text doesn't have a section on telescoping series.
Probably the first theorem on infinite series says if ##\sum_{n=1}^\infty a_n## converges, then ##a_n\rightarrow 0##. The contrapositive of this statement is that if ##a_n## does not go to zero, the series diverges. The nth term of a convergent series must go to zero. Otherwise the series diverges. But note that the nth term going to zero is only a necessary condition for convergence of the series, it isn't sufficient. If it were sufficient you wouldn't need all those convergence tests. All you would have to check is whether the nth term goes to zero. Too bad life isn't that simple.
In my book, the only example on telescoping series deals with partial sums. I didn't understand any of that before, as i just crammed over it. But now i appreciate that there are 2 different kinds of sequences associated with series. That little piece of crucial information is unfortunately not mentioned anywhere as I've reviewed that chapter several times.
But i have a doubt: for the series to converge, the sequence an must converge to 0, but does that mean that the series converges to 0?
No. Remember the series represents the sum of all its terms.
This agrees perfectly with what vela has said in his reply above. Thank you for elaborating the concept of contrapositive. I didn't fully understand that term before.
It's a tricky chapter, and it took me almost a year to reach this point. Really! But i believe i finally understand how it works.
1. What is the definition of convergence in a series?
The convergence of a series can be defined as the property of a series in which the sum of its terms approaches a finite limit as the number of terms in the series increases.
2. How do you determine if a series is convergent or divergent?
There are several tests that can be used to determine the convergence of a series, such as the Ratio Test, the Comparison Test, and the Integral Test. These tests involve analyzing the behavior of the terms in the series and can help determine whether the series is convergent or divergent.
3. Can a series be both convergent and divergent?
No, a series can only be either convergent or divergent. If the sum of the terms in a series approaches a finite limit, then the series is considered convergent. However, if the sum of the terms does not approach a finite limit, the series is considered divergent.
4. What is the importance of knowing the convergence of a series?
Knowing the convergence of a series is important because it can help determine the behavior and properties of the series. It can also help in making calculations and predictions based on the series, as well as in finding the sum of the series if it is convergent.
5. Can a divergent series be manipulated to become convergent?
No, a divergent series cannot be manipulated to become convergent. However, it is important to note that some series may have conditional convergence, meaning that the series only converges under certain conditions or rearrangements of the terms. In these cases, manipulating the series may change it from conditionally convergent to divergent.
