How to Write Loop Equations for a Circuit with Multiple Resistors and Batteries
  • Thread starter Thread starter Cisneros778
    Current Resistor
The discussion centers on solving a circuit problem involving five resistors and two batteries, focusing on the confusion surrounding the derivation of loop equations. The provided equations include a mix of Kirchhoff's Voltage Law (KVL) and Kirchhoff's Current Law (KCL), leading to misunderstandings about their application. The correct loop equations are identified, with emphasis on the relationships between currents in different resistors. Participants suggest that writing out the loop equations independently may clarify the current relationships. The final current through the 4-Ω resistor is confirmed as 1.51 A, highlighting the importance of correctly applying KVL and KCL.
Cisneros778
I do not understand the solution provided for this problem.
Consider the circuit with five resistors and two batteries (with no internal resistance) shown in the figure.
(b) Solve for the current in the 4-Ω resistor.
loop law
junction law
The answer below is correct, however I am confused on how equations (2) and (3) were found.
(1) 12 - i1 -3i2 =0
(2) 6 -5 i1 +8i2 -4i3 =0
(3) 6 + 2 i1 -2 i2 -6i3 =0
solving the above we get
i1= 4.16
i2 = 2.61
i3 =1.51
current through 4-O resistor = i3 = 1.51 A
I think you are confused between KVL and KCL that is loop law and junction law resp. as you mentioned. No the answer is not right and since its loop equation given as sum of all the voltages in a loop but you are using junction law with it.
(1) 12 - i1 -3i2 =0
It looks like (2) is the loop equation for the loop 6V-3Ω-4Ω-5Ω, and (3) is the loop equation for the triangular loop in the upper right part of the circuit.
Try writing out these loop equations yourself. To do that you'll need to figure out:
The current in the 5Ω resistor, in terms of i1 and i2, and
the current in the 2Ω resistor, in terms of i1, i2, and i3.​
