Find position after t for simple harmonic motion
A 28.0 kg block on a frictionless air track is pushed to x=0.350 m and released, initiating simple harmonic motion with a period of 4.70 s. The position of the mass after 3.854 s was initially calculated using the sine function, but the correct approach requires a phase angle or using cosine for accurate results. The spring constant k was determined to be 3.92, and the amplitude A is given as 0.35 m. The maximum acceleration can be calculated using the formula a=omega^2*cos(omega*t). The discussion highlights the importance of correctly applying the formulas for position and acceleration in simple harmonic motion.
smillphysics
A 28.0 kg block at rest on a horizontal frictionless air track is connected to the wall via a spring. The equilibrium position of the mass is defined to be at x=0. Somebody pushes the mass to the position x= 0.350 m, then let's go. The mass undergoes simple harmonic motion with a period of 4.70 s. What is the position of the mass 3.854 s after the mass is released?
T=2pi*sqrt m/k
KE1+PE1=KE2+PE2 from this you get mv^2=KA^2
x=Asin *omega*t
omega=2pi*frequency
frequency =1/T
I used the first equation get k=3.92
then I use that k in the second equation, but I don't know how to get v to then get A. Any help? Would I then take that A and plug it into the third equation to get my X?
In the given problem the amplitude A is given. ( 0.35 m). Find x.
So I plugged in A (.35m) into the equation,
x=.35sin(1.34*3.854) and got x=.032 which is still incorrect? Any help on where I am going wrong?
The second part of this problem calls for the maximum acceleration- would I use the equation a=omega^2cos omega *t? I don't think that I will get this problem correct if I got the last one incorrect.
Your formula for posistion does not work at t=0! You need a phase angle in it, or use cosine instead of sine.
I figured this problem out. Thank you!
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
