Find Speed and conservation of energy.
soulja101
is there away of finding the speed of an object using the law of conservation of energy?
Of course, remember the kinetic energy.
thnx a lot i ve tried it and i actually got the right answer
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
