Find Stable Equilibrium for Mass m=5.34Kg w/ Force F(x)
The discussion centers around finding the position of stable equilibrium for a mass of 5.34 kg under the influence of a specified force function, F(x). The participants are also exploring the frequency of oscillation around this equilibrium position and how it may change with a different force function.
  • The original poster attempts to find the equilibrium position by setting the force F(x) to zero, resulting in potential solutions of x=0 and x=25. Some participants question the notation used in the force expression and seek clarification on the calculations. There is also a suggestion to consider the differential equation for harmonic oscillators to approach the frequency calculation.
Participants are actively engaging with the problem, with some providing hints and guidance on how to approach the frequency calculation. There is an acknowledgment of confusion regarding notation and calculations, indicating a collaborative effort to clarify and explore the problem further.
There is mention of potential mistakes in calculations, particularly regarding the inclusion of mass in the force expression. Participants are also discussing the implications of different force functions on the frequency of oscillation.
jjj2364
I have a object of mass m=5.34Kg. There is a force acting on the object F(x)=(5.0N/m[1][/2])*(x[1][/2])-(1.0N/m)*(x).
1)I need to find the position x0 where the mass is in a condition of stable equilibrium.
2)What is the frequency of oscillation around this position? How would this frequency change if the force was F(x)=(1.0N/m)(x)
Relevant equations:
F(x)=0 in order to get the position of stable equilibrium.
The attempt at a solution
I put the force F(x)=0 and I got x=0 and x=25 but I'm not sure this is the right way to do it.
For part 2 I'm a little confused, could give some hints?
thanks
jon
That's the right way to do it, but I can't check your answer because I don't understand your notation. What do m[1][/2] and x[1][/2] mean?
For part 2, think about the differential equation for a harmonic oscillator:
d2s/dt2 + w2s=0
where s represents a small deviation from the equilibrium position. Try taking the second time derivative of x, then rewriting it in the form above, using Taylor series approximations if necessary. w^2 would then give you the frequency.
ok
sorry i was not sure about the way to write that
this is the expression for the force
F(x)=(5.0N/m^1/2)*(x^1/2)-(1.0N/m)x
m=mass
so the first term contains the sqrt of m and the sqrt of x.
I think i made a mistake in the calculation because i didi not plug in the value for the mass. I'm going to do that again and I am going to try to do part two.
thanks!
bob
so i got x=0 and x=133.42
