Find the acceleration of a pulley system
The discussion revolves around determining the acceleration of a pulley system involving two masses, m1 and m2, with specific values provided. The mass of the pulleys is disregarded, and the rope is described as non-stretchable.
  • Participants explore the forces acting on the masses and the resulting tensions in the rope. There are questions about how the forces from m1 and m2 interact and how to represent these forces mathematically.
Participants are actively discussing the forces involved and their implications for the system's acceleration. Some have provided insights into the distribution of forces and tensions, while others are questioning the assumptions about equilibrium and the effects of acceleration on the system.
There is an ongoing discussion about the assumptions regarding the tension in the rope and the conditions under which the system operates, particularly whether it is in equilibrium or accelerating.
AndrejN96
Find the acceleration of the system shown on the image, given m1=0.1kg and m2=0.3kg. Mass of pulleys is to be disregarded, and rope is non-stretchable.
m1*a=m1*g-T
I am unsure of how the forces of the second body would act and in what direction. Any help is appreciated.
Look at m2. It obviously pull the pulley with a force m2 * g. And that force divides in two parts...
Imagine that your mass is, for example, 70 kg, and hence your weight 70 * 9,8 = 686 N, and that you sit on the table of a swing that is fastened to an horizontal beam above with two chains. How much of your weight do you think is supported by each chain...? Well, the same thing happens with m2
My first thought was that it spreads the force applied in half, but how would the equations look like in that case?
Leave the equations apart for the moment, and just think about the forces involved. ¿What force is caused by m1? And what forces are caused by m2?
Well m1 would cause tension on the rope, and m2 would cause tension on both parts of the rope but with lower intensity (?)
Yes, but how much lower...? You have already written the right answer above...
Once you decide which are the forces involved, write them down and/or calculate them, and then you should deduce the net force.
I just did some more research in literature I have on physics. It says the tension would be the same in all 3 places of the pulley system, because the rope and pulley are light enough to be disregarded.
Look at the right rope, the one that is anchored to the floor. Along that length of rope, there is a force that is one-half of m2 * g. It is canceled by the same reaction from the roof.
Now, we look at the left rope rising from the pulley that holds m2. Along that length of rope, you also have one-half of the force caused by m2 Let's write it down: F1 = (m2 * g)/2.
But that length of rope is also affected by another pulling force, that coming from m1. We also write it down: F2 = m1 * g.
It's easy to see that F1 and F2 are opposed. Evidently, the net force is their difference...
Go on now... There is little left to solve the problem...
This is only true of the system is in equilibrium. In general the system will be accelerated and the only thing you can say about the tension in the rope is that it is the same in all parts. You will then have to relate the tension to the acceleration and geometry of the problem.
Yes, thanks, this was the confirmation that I needed. Cheers!
  • · Replies 17 ·
  • · Replies 22 ·
