Find the amount of work to move a particle from point A to B
The discussion focuses on calculating the work required to move a point charge of 15 nC from infinity to a distance of 3 cm from a charged sphere with a diameter of 15 cm and a surface charge density of 12 µC/cm². The relevant equations include W = ΔU = q * ΔV and W = q(kQ/Rf - kQ/Ri). Participants clarify that the total charge Q can be derived from the surface charge density and the sphere's surface area, emphasizing the importance of correctly determining the radius in the calculations.
  • Understanding of electrostatics and point charges
  • Familiarity with the concept of electric potential and work
  • Knowledge of surface charge density calculations
  • Proficiency in using the formula for the area of a sphere
  • Calculate total charge Q using surface charge density and sphere area
  • Review the concept of electric potential V = kQ/r in electrostatics
  • Explore the implications of using point charge approximations for spherical charge distributions
  • Investigate the relationship between work and electric potential in electrostatic systems
Students studying electrostatics, physics educators, and anyone involved in solving problems related to electric fields and potentials.
Aleksandre
How much work should be done on a point charge of q=15 nC to bring it from infinity to a distance of 3 cm from a surface of a charged sphere? Diameter of sphere is 15 cm, its surface charge density is 12 microC/cm2
W=deltaU=q*deltaV
v=kQ/r
W=deltaU=q(kQ/Rf -kQ/Ri)
If point charge is placed in infinity then initial distance would be infinity which means kQ/Ri=0. Then we are left with equation:
W=q(kQ/Rf).
k is constant, q is known=15 nC and Rfinal=0.03 meters as given. The only uknown would be Q, e.i charged sphere. Now I have everything but have no idea how to calculate Q. Can you assist me?
Thanks.
Note that you are given the surface charge density of the sphere.
Your value for Rfinal is not correct. What is the physical meaning of r in V = kQ/r?
i think Q can be calculated using surface charge density ... because the total charge may be considered to be concentrated at the centre. check the theory...
only the r value has to be taken properly
Thanks for reply, so to reformulate:
Area of sphere = 4pir2 =>4*3.14*0.152
Total charge Q would equal to(?) = 0.12C/m2*Area of Sphere
Then if sphere centre can be considered as a point charge(?) the Rfinal would be radius of sphere+distance to charge?
Yes. But note that the radius of the sphere is not 0.15 m.
Yes.
  • · Replies 22 ·
  • · Replies 35 ·
