Find the change of internal energy of the air.
The change of internal energy of air in a car rubber can be calculated using the formula U = (5/2)nRT, where n is the number of moles of air. Given a volume of 50 liters, an initial pressure of 1.8 atm, and a temperature of 293 K, the number of moles (n) is determined to be approximately 3.7. After the pressure increases to 2 atm, the change in internal energy is calculated to be 2500 J, which aligns closely with the textbook answer of 2537 J when accounting for significant figures and using precise values for atmospheric pressure.
  • Understanding of the Ideal Gas Law
  • Familiarity with the formula for internal energy of an ideal gas
  • Basic knowledge of thermodynamics
  • Ability to perform calculations involving pressure, volume, and temperature
  • Study the Ideal Gas Law and its applications in thermodynamics
  • Learn about the internal energy equations for diatomic gases
  • Explore the significance of significant figures in scientific calculations
  • Investigate the properties of air as a mixture of gases
Students studying thermodynamics, physics enthusiasts, and anyone interested in understanding the behavior of gases under varying conditions.
MaiteB
A car rubber has the volume 50 liters when it is bloated in a pressur 1.8 atm and in a temperature 293 K. After some hours of journey as an effect of friction the pressure will become 2atm. Find the change of internal energy of the air inside the rubber (U)
U=3/2nRT
I thought to sue the formula U=3/2nRT, but I don't know the n.
Don't forget the ideal gas law. Also, in the formula for U, are you sure the fraction is 3/2? Nitrogen and oxygen are diatomic gases.
Ok but how can I find the U with this compound of gases like air?
I am writing my solution: pV=nRT=>n=(1.8*10^5*0.05)/(8.31*293)=3.7
1.8/293=2/x=>x=325.5555
U= 5/2* 3.7*8.31*(325.56-293)=2500, but in my book the answer is 2537J
Looks good. Some of the data in the problem is given to only 2 significant figures. So, the textbook should have rounded the answer to 2 significant figures which agrees with yours.
If you use 1.01325 x 105 for atm you find a better number. Your calculation is correct.
