Find the coefficient of static friction
The problem involves determining the coefficients of static and kinetic friction for a chair on a horizontal floor, given specific forces required to initiate and maintain motion. The subject area includes concepts of friction and Newton's laws of motion.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the forces acting on the chair and the equations related to friction. Some express uncertainty about the appropriate formulas to use, while others suggest using the static and kinetic friction equations. There is a question about whether to multiply the friction forces by the weight of the chair to find the coefficients.
The discussion is ongoing, with participants exploring different approaches to the problem. Some guidance has been offered regarding the relationships between forces and coefficients of friction, but there is no explicit consensus on the method to solve the problem.
Participants note the absence of a textbook for reference, which may contribute to the uncertainty in identifying the correct equations. There is also a mention of needing to find both static and kinetic friction coefficients, indicating a two-part problem.
sprinter08
A 25kg chair initially at rest on a horizontal floor requires a 165N horizontal force to set it in motion. Once the chair is in motion, a 127N horizontal force keeps it moving at a constant velocity.
a.) Find the coefficient of static friction between the chair and the floor.
b.) Fing the coefficient of kinetic friction between the chair and the floor.
3. The Attempt at a Solution
I'm not really sure what equation to use the solve the problem. I know that it is probably something really easy as sticking the numbers into a formula, but I don't know the formula, and we don't use a book, so I can't look it up.
F=mg
f=mgu
165N is the static friction force
127N is the kinetic friction force
simply put in the number f(s)=F*u
so would I take 165 and multiply it by the weight of the chair (25 kg) to find static friction and multiply 127 by 25 to find kinetic friction?
F=mg=25x9.8
for question 1.) f=Fu ---> 165=25x9.8xu find u , u is the coefficient of static friction between the chair and the floor.
try to do 2 by yourself
