Find the current by adding the resistances
  • Thread starter Thread starter ashleydeer7
    Current
To find the current in a circuit with capacitors and resistors, first determine if the resistors are in series or parallel. In a series circuit, the total resistance is the sum of individual resistances, allowing the application of Ohm's law to find the current. For capacitors, the current through them is zero initially, so the voltage across the resistors must be calculated to understand the voltage seen by the capacitors. In parallel circuits, the current can be found in each branch, and the voltage across the capacitors can be determined from the voltage at each end. Understanding these relationships is crucial for solving the circuit effectively.
ashleydeer7
http://i260.photobucket.com/albums/ii10/alexlovely77/af.jpg
q=cv
i just want help with 1 of the 3 (anyone...)
so the first one...the current thru the capacitors is 0
then u have to find voltage right?
but how do u find the voltage thru those resistors?
r the 3 resistors in series? or do the capacitors make them not in series?
In the first, the resistors form a simple series circuit. Find the current by adding the resistances, then apply Ohms law. Once you have the current you can find the voltage drop across each resistor. This will give you the voltage seen by the capacitors.
In the second you can easily find the current in each branch of the parallel circuit. You can then find the voltage at each end of the cap. The difference is the voltage used to find the charge.
