Find the frequency of the lowest note a piccolo can sound
  • Thread starter Thread starter ~christina~
    Frequency Sound
The discussion centers on calculating the frequency of the lowest note a piccolo can produce, given its length of 32 cm and the speed of sound at 340 m/s. The lowest note corresponds to the longest wavelength, which features a node in the middle and antinodes at both ends. For part b, the focus shifts to determining the distance between adjacent antinodes for a sound wave at 4,000 Hz, with some participants noting that the piccolo's length may not be relevant for this calculation. Clarifications on the definitions of nodes and antinodes are provided, emphasizing their importance in understanding sound wave behavior. The conversation concludes with participants expressing gratitude for the assistance received.
~christina~
The overall length of a piccolo is 32cm. The resonationg air column vibrates as in a pipe open at both ends.
a) find the frequency of the lowest note a piccolo can sound, assuming the speed of sound in air is 340m/s
b) opening holes in the side effectively shorten the length of the resonant colum. Assume the hightest not a piccolo can sound is 4,000 Hz. Find the distance between adjacent antinodes for this mode of vibration.
open pipe harmonics
f_n= n \frac{v} {2L}
first of all for
I'm not sure what would be the definition of lowest note. Do they mean sound.
thus the \lambda??
help?
Thanks
Hi christina!
The lowest note would be the one with the longest wavelength, which I think is the wave with a node in the middle of the column, and the maximum amplitude at both ends. :smile:
tiny-tim said:
Hi christina!
I figured out part a) but how do I do part b?
Thank you.
Hi christina!
I think the fact that it's a 32cm piccolo is irrelevant.
Question (b) just asks you for the antinode distance (which would be the same as the node distance) for any 4000Hz sound wave in air. :smile:
tiny-tim said:
Hi christina!
Hello tiny-tim
Thanks for your help.
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
