Find the Friction (Rotational Problem)
  • Thread starter Thread starter proximaankit
    Friction
4 replies · 3K views · last reply
proximaankit
One afternoon, you are playing on a wooden basketball court with a hula‐hoop to amuse yourself. The hoop has a mass of 500g and a radius of 55 cm. After practicing a bit, you find that you can launch the hoop so that its plane is vertical, it isn’t rotating before it hits the floor, and it doesn’t bounce after hitting the floor. For these launch conditions, the hoop’s CM moves initially with a speed of 3 m/s along the floor. You notice that as the hoop slips along the floor it begins to rotate, and that just before it hits the far wall 20 m away from the launch point, it “catches” and begins to roll without slipping. What is the coefficient of kinetic friction between the hoop and the floor?
τ=Iα=f*r where f is frictional force
f=μmg
f=ma
I = MR^2
Tried various method to solve for μ, but it ends up canceling itself. i.e.:
f*r=MR^2*(a/r)
a=f/M
f =f/M
Please show your reasoning.
Notice that the hoop slides for a while before it "catches" - what is happening in this part of the motion?
What is the condition for rolling without slipping?
f=μmg
f=ma
I = MR^2
f*r=MR^2*(a/r)
a=f/M
f =f/M
It's rather hard to follow if you keep using the same symbol (f) to mean different things. Please define all your variables and name them uniquely.
Sorry for the confusion but here is what I was trying to do
At the bottom of the hoop, as the hoop starts to rotate, that must mean that friction is causing the rotation. In my free body diagram I had. friction to left of point of contact and Normal up and weight down. Friction acting on the object cause it rotate so it will have angular acceleration. Friction cause the hoop to have acceleration since it should be slowing down. so f (friction ) = ma. By torque eqn. τ=f*l=Iα=MR^2(a/r) -> which arrives to the same equation of f = ma. And from here I am lost.
You got the same equation because you assumed αr = a. But you can only be sure of that once it is rolling. So these equations are telling you something you didn't know, that αr = a holds even while it is slipping. But it might not be terribly useful.
Think about velocity. You are given the initial linear and rotational velocities, and a relationship between the final velocities.
