Find the integer that is nearest to the area of complex plane A
The discussion revolves around finding the area of a specific region A in the complex plane defined by conditions on the real and imaginary parts of \(\frac{z}{40}\) and \(\frac{40}{\overline{z}}\). The constraints lead to the realization that both \(a\) and \(b\) must be between 0 and 40, with the equation \(a^2 + b^2 = 1600\) indicating a circular boundary. The area of interest is described as the region above and to the right of two intersecting circles, extending into the first quadrant. The area can be calculated by subtracting the white area from the total square area of 1600. Ultimately, the integer nearest to the area of A is determined through geometric analysis.
Greychu
Consider the region A in the complex plane that consists of all points z such that both \frac{z}{40} and \frac{40}{\overline{z}} have real and imaginary parts between 0 and 1, inclusive. What is the integer that is nearest the area of A?
Let z = a + bi and \overline{z} = a - bi
a = real part of z, b = imaginary part of z
substitute z and \overline{z}, we get
\frac{z}{40} = \frac{a + bi}{40}
\frac{40}{\overline{z}} = \frac{40(a+bi)}{a^{2} + b^{2}}
Since both both \frac{z}{40} and \frac{40}{\overline{z}} have real and imaginary parts between 0 and 1, inclusive:
Hence
For \frac{z}{40}:
0 < \frac{a}{40} < 1,
0 < \frac{b}{40} < 1
For \frac{40}{\overline{z}}:
0 < \frac{40(a)}{a^{2} + b^{2}} < 1,
0 < \frac{40(b)}{a^{2} + b^{2}} < 1
From these 4 equations, if 0 < a < 40 and 0 < b < 40 are fulfilled, then
a^{2} + b^{2} = 1600
Well the problem is I don't know how to find out the area A, since the points z can be randomly distributed in the range of 0 < a < 40 and 0 < b < 40. Any ideas?
If assuming the complex plane is an square with a = x = 40 and b = y = 40, the area is 1600, which is differ from the answer.
Source:
http://en.wikipedia.org/wiki/International_Mathematical_Olympiad
It helps to know about geometrical inverses. If you 'invert' a straight line with respect to a point off the line you get a circle.
The ##\frac 1{\bar z}## is equivalent to such an inversion. Inverting the two lines x=1/40, y=1/40 thus gives two intersecting circles as shown in the diagram at the link provided. The region of z for which ##\frac {40}{\bar z}## has real and imaginary parts between 0 and 1 is therefore the grey area to the right and above those circles, but extending off to infinity in the rest of the first quadrant. Combining with the other constraint leaves just the grey area.
Finding its area is easy. The white area can be cut into two quadrants and a square.
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
