Find the kinetic energy of the system
In the discussion about calculating the kinetic energy of two bighorn rams in an elastic collision, participants emphasize the importance of using both conservation of momentum and conservation of kinetic energy. One user attempts to derive the initial velocity of the alpha male using a quadratic equation, expressing uncertainty about the complexity of the solution. Another participant clarifies that elastic collisions require both conservation principles to be applied correctly. The conversation highlights the need for careful calculations, as the quadratic equation will yield two solutions, one of which represents a scenario where the rams miss each other. Overall, the discussion centers on the correct application of physics principles to solve the problem.
milkyway11
The question states: two adult bighorn rams butt heads in an elastic collision. the alpha male 136kg moves slower than his challenger that's 113kg. If the challenger collides at 8m/s and is repelled at 6m/s, find the kinetic energy of the system and the percent increase in speed that the alpha male experience.
I tried to solve the problem by using the conservation of momentum. However, since I don't know the initial nor final velocity of the alpha male, I decided to use the conservation of kinetic energy and find the Vi in terms of Vf. but that means I have to solve a v^2+v+c=0 (sorry, forgot what it was called). So i am not sure if i did it correctly since it is so complicated.
hi milkyway11! :smile:
(try using the X2 and X2 icons just above the Reply box :wink:)
milkyway11 said:
… in an elastic collision …
… I decided to use the conservation of kinetic energy …
"elastic" collision means that you must use conservation of energy (as well as conservation of momentum, which applies in all collisions)
… but that means I have to solve a v^2+v+c=0 (sorry, forgot what it was called). So i am not sure if i did it correctly since it is so complicated.
(it's a quadratic equation :smile: …)
it has to have two solutions, because one solution will always be for the two objects to completely miss each other, won't it? :biggrin:
Thank you for your reply!
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
