Find Limit: <Undefined,Undefined,6/5>
  • Thread starter Thread starter Whatupdoc
    Limit
The limit problem presented involves evaluating three expressions as t approaches 0. The first two terms yield an indeterminate form of "0/0," which requires further analysis, potentially using L'Hopital's rule or algebraic manipulation. The second term can be simplified by factoring, leading to a limit of -1 as t approaches 0. The first term relates to the derivative of e^(-5t), which evaluates to -5 at t=0. The final result for the limit is confirmed to be < -5, -1, 6/5 >.
Whatupdoc
Find the limit:
lim, t->0 &lt; \frac{e^{-5t} - 1}{t}, \frac{t^{13}}{t^{14}-t^{13}}, \frac{6}{5+t}&gt;
answer: <__,__,__>
well, what i did is just plug in zero for t which i get <0,0, 6/5> which is incorrect. am i missing something? or actually it should be <undefined,undefined, 6/5>
For the first term, try l'Hopital's rule. For the second term, see if you can write the expression using only t^{13} and lower powers of t (splitting the denominator into two multiplicative terms would help a lot), and the third term of course doesn't pose a problem.
Whatupdoc said:
Find the limit:
answer: <__,__,__>
Well, first, as I think you understand, "plugging" in 0 does not give 0 for the first two! Neither does it give "undefined"- the limit may exist even if the value does not.
Some texts make a distinction between "a/0" when a is not 0 and "0/0". Of course, neither is a number but we often refer to "0/0" as "undetermined" rather than "undefined". "a/0" is undefined because if we try to set x= a/0 we get x*0= a which is not true for any x. If set x= 0/0, however, we get x*0= 0 which is true for all x. We still can't give a specific value for x so it is "undetermined".
This is important here because: if f(x)-> a, a nonzero number, and g(x)->0, then f(x)/g(x) must get larger and larger- there is no limit, the limit is "undefined".
If f(x)->0 and g(x)->0 also, then f(x)/g(x) may have a limit. For an obvious example, take f(x)= x and g(x)= x. As x-> 0, both of those go to 0 but their quotient is x/x= 1 (as long as x is not 0) which has limit 1 as x goes to 0.
For your example, both the first two components become "0/0" (all interesting limits do!) so you need to look more closely. You could, as Brinx suggested, use L'Hopital's rule but that is not necessary.
The second component is a little simpler than the first:
That is one polynomial divided by another. The fact that t=0 make both of them 0 means that we can factor t out of both! In fact, t14-t13= t13(t- 1). Now, you can cancel and be left with \frac{1}{t-1}. What is the limit of that as t goes to 0?
The first is a little subtler.
Do you know that the derivative of e-5t is -5 e-5t and so the derivative at t=0 is -5?
Do you recognize that first component as being exactly the "difference quotient" you would use in the basic definition (replacing t with "h" perhaps) to find the derivative of e-5t at t= 0?
ahhh, i forgot all about the L'hopital rule. thanks a lot for the long explanation, i totally get it now
