Find the magnitude and direction of the net displacement of the player
The discussion focuses on calculating the net displacement of a basketball player running along specified vectors A, B, and C. The player’s displacement components were found to be Dx = 20m and Dy = 0m, leading to confusion regarding the resultant angle when Dy equals zero. Participants clarify that the angles of vectors A and B are 45 degrees and 30 degrees, respectively, while questioning the angle of vector C. After recalculating the components, the resultant angle was determined to be approximately 1.81 degrees. The conversation highlights the importance of accurately interpreting vector angles and their directions in displacement calculations.
matt@USA
A basketball player runs down the court, following the path indicated by the vectors A,B, and C in the figure. The magnitudes of these three vectors are 10, 20 and 7 m . Assume the positive x-axis is directed to the right.
There is a 45degree angle outside of where A and B meet, and there is a 30degree angle outside of where B and C meet.
I have found what Dx and Dy are. Dx and Dy are 20m, and 0m. In order to find the degree of the equation you would have to take the tan^-1(Dy/Dx). My question is, how do you solve this when Dy = 0? The answer is not 0 degrees, I know this for a fact. Thanks for all the help!
if dy is zero, then the resultant angle should also be zero.
You must have added the components incorrectly. It's hard for me to imagine your details. Basically, I think youre trying to say that the angle vector A makes with the horizontal is 45 degrees, the angle vector B makes with the horizontal is 30 degrees, but what about the angle that vector c makes with the horizontal? what's that?
No, I know my answers are correct because I had to solve for the absolute value of vectors A, B, and C, and they were correct. Imagine vector A going south. Then vector B heads off to the North East. Then vector C heads to the south east.
so dy= -10 + .707(20) + -.5(7)=.64
and dx=.707(20) + (sqrt3)/2 times 7=20.2
resultant theta=tan-1(.64/20.2)= 1.81degrees.
the only thing I'm scepticle about is the who idea of the 30 degrees south of east you gave. It could actually mean 60 degrees above horizontal, but I can't see the problem in your book or the source you got it from.
