Find the minimal polynomial with real root
Daveyboy
Find the minimal polynomial with root 21/3 + 21/2.
I would just use maple but I do not have it installed on this machine.
I found the polynomial and verified that this is indeed a root. I only have Eisenstiens criterion for determining whether it is irreducible, and I can not apply it in this case. Do you have another method? I have not tried substituting x=x+1 or x=x-1 or other substitutions.
The polynomial is x6-6x4-4x3+12x2-24x-4
Try computing [ \mathbb{Q}(\sqrt[3]{2} + \sqrt{2}) : \mathbb{Q} ].
Or... the dimension of the vector space spanned by powers of \sqrt[3]{2} + \sqrt{2}.
Or... something else that would tell you information about the minimal polynomial.
You don't need to show the polynomial is irreducible, do you? You just want to show it has no rational roots. Look at the rational root test. If that has a rational root, the root must divide 4.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
