Find the speed of the alpha particle after the reaction
The discussion revolves around calculating the speed of an alpha particle resulting from a nuclear reaction involving a neutron and boron. Participants emphasize the importance of considering the masses of the particles involved rather than just their nucleon counts. There is confusion regarding mass changes, prompting suggestions to look up actual particle masses for accurate calculations. The concept of binding energy is introduced, highlighting its significance in understanding mass differences in nuclear reactions. Accurate mass values are essential for determining the speed of the alpha particle post-reaction.
student34
For the nuclear reaction, 1 neutron (1/0n) + 10/5B → 7/3L + 4/2He (alpha particle) assume that the initial kinetic energy and momentum of the reacting particles are negligible. Calculate the speed of the alpha particle immediately after it leaves the reaction.
E = mrestc^2
Ek = (mtotal (before) - mtotal (after))c^2
I really have no idea because there is no change in mass that I can see, and that is all I had to look for with questions similar to these in this chapter.
##\renewcommand{\e}[1]{\text{#1}} \e n_0^1 + \e B_5^{10} \to \e{Li}_3^7 + \e{He}_2^4##
Did you look up the masses or just go by the number of nucleons?
Likes 1 person
I only used the number of protons and neutrons. I can't think of any other reason why they would have a different mass.
I'd check the masses out then :)
Likes 1 person
Yep - go look up the masses :)
Write back with a list.
Consider: where does the "binding energy" of a nucleus come from?
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
