Find the tension in the rope pulling a box at an angle
The discussion revolves around calculating the tension in a rope pulling a box at an angle, with a focus on the equations of motion. The user initially misapplied the vertical force equation by including acceleration, which led to confusion about the normal force and frictional force calculations. Clarifications were made regarding the correct formulation of the normal force and the role of kinetic friction, denoted as 'uk'. The user was guided to reevaluate their equations, particularly the relationship between tension, normal force, and the forces acting on the box. The conversation emphasizes the importance of correctly setting up the equations to avoid negative values for tension and to ensure accurate calculations.
qwertyqwert321
Here is what i have done so far:
Fx = cos 45 T - Ff =ma
Fy=sin 45 T -mg+ Fn =ma
I found ff= uk * Fn = 0.5 *sin 45 +mg
fn = sin 45 +mg
Isolated for T in the x and y:
Tx = ma + Ff / cos 45 = 13.404
Ty = ma +mg - Fn / sin 45 = 83.938
found the resultant for T: sqrt( (13.404)^2 + (83.938)^2 ) = 85 N?What am i doing wrong? I've been stuck on this for 3 +hours now with no help :(
the answer is meant to be E.
qwertyqwert321 said:
Fy=sin 45 T -mg=ma
Presumably ##F_y## denotes the vertical component of net force on the box. That '=ma' should not be there. The acceleration is strictly horizontal, so ##a## shoud not appear in this equation about vertical components. Also, note that writing ##F_y## this way, in which the positive direction is up, it will be negative, because there cannot be a net upward force on the box, otherwise it would move upwards off the floor rather than horizontally along it.
I found ff= uk * Fn = 0.5 *sin 45 * mg
I don't know what 'uk' is. Assuming that 'ff' denotes frictional force, that force will be ##0.5F_y##, not what is written here.
In the question, they stated the kinetic friction as 0.5 , which is what uk is.
and frictional force, ff, is uk * normal force (fn), therefore Ff = uk * Fn ? right?
I made the second equation as you said:
Fy=sin 45 T -mg+ Fn =0
solved for T and got -0.9998
i must be doing something wrong, I am just not sure what
We cannot tell where you went wrong if you do not post your working.
The two equations had up to that point look correct.
okay i now understand that I got the normal force equation wrong it is:
Fn = mg -T sin 45
why is the tension force negative? isn't Ty in the upward positive direction?
Fn = mg -T sin 45
Yes, I understood that you had got that equation correct, but that still does not show me how you got from there to a wrong answer. Please show all your steps.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
