Find the time required to complete each cycle
The discussion revolves around calculating the energy absorbed and the time required for each cycle of an engine with a power output of 6.00 kW and an efficiency of 26.0%. To find the energy absorbed in each cycle, the relationship between power, energy, and time is emphasized, noting that 1 kW equals 3.6 million Joules. The participants clarify that kW measures power while Joules measure energy, requiring time for conversion. The confusion about the engine expelling energy is addressed, highlighting the importance of understanding the units involved in the calculations. Overall, the conversation focuses on the principles of thermodynamics and unit conversions necessary for solving the problem.
sun
A particular engine has a power output of 6.00 kW and an efficiency of 26.0%. Assume the engine expels 6000 J of energy in each cycle.
(a) Find the energy absorbed in each cycle.
(b) Find the time required to complete each cycle.
P=W/delta t
e=W/Q
1kW=3.6x10^6J
Because the engine is expelling 6000J, does this mean it is negative? I'm not quite sure how to approach this problem.
I suspect that if you start with a unit analysis the solution will jump out.
Gary
Things aren't that obvious to me :(.
I came to the realization that 1kW=3.6x10^6J, so 6kW=2.16x10^7J.
kW aren't directly convertable to J. 1J = 1W x 1s or one Joule equals one Watt-Second. What you have is the conversion of a kW-hr (kilowatt-hour) to a Joule.
The Watt is a measure of power. The Joule a measure of energy. To move between power and energy time must be considered.
Gary
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
