Find Vol 2 in Ideal Gas Law Problem with V1 and V2 Open and V3 Shut
The discussion revolves around calculating Vol 2 in an ideal gas law problem involving multiple valves (V1, V2, V3) and pressure measurements. Initial conditions are established with V1 open and V2 opened for pressure equalization, but insufficient final conditions are provided to determine Vol 2 accurately. The participants confirm that without knowing the final conditions after V3 is opened, Vol 2 can be arbitrary without violating any facts. Measurements taken after opening V3 include pressures from a capacitance manometer, indicating a significant drop in pressure. The conversation highlights the importance of accurate temperature and unit conversions in gas law calculations.
Catstranaughts
Find Volume of gasline: I have known pressure chamber (vacuum) that P= 1e-6 Torr. Volume is 101L. T = 25C. I can easily solve for n. But now I have a gasline with an unknown volume which I'm trying to calculate. I know the pressure of the gasline. but I also don't know the number of molecules in the gas line.
PV =nRT
Please refer to diagram. V1 is open initially then V2 is open for 5 minutes for pressure to equalize. V1 and V2 are then shut. V3 is opened. What is Vol 2 ? P(final)*V(final) = n(final)* R*T => (Vol1 + Vol2) = n(final)*R*25C/ 0.070 Torr where n(final) = n(Vol1) + n(Vol2)
If I shut V3, I can find the n(Vol 1), but i still don's know n(gasline) so I can't find Vol 2. Is there enough information given to solve this problem ?
If I understand the problem statement, you are given all the conditions prior to opening V3 except Vol2, and no final conditions. If so, it is clear that there is insufficient information. You can make Vol2 whatever you like and no facts are violated.
Please check that no final conditions are given.
Just a note on your formula: PV = nRT. Make sure your temperature is absolute (either Kelvin or Rankine). Also, your units for volume and pressure should be consistent with the units for R.
Thanks haruspex. This is in a lab. There is a mass flow controller in the gasline. But this leaves the volume measurement dependent upon the accuracy of the MFC and gas correction factor associated with it. Is there other information I can gather to help solve this ?
Thanks Dave, I'm converting to K and atm (and using liters)
Catstranaughts said:
This is in a lab.
So what measurements were taken after opening V3?
You'd need to explain to me what that does.
Pressure in the system by a capacitance manometer. Pressure before V3 is open: P(gasline) = 760 Torr. P(chamber = 1e-6 Torr). Pressure after V3 open: P Gasline = Pressure Chamber = 70mTorr.
For the test, the Mass Flow Controller was programmed to max value to fully open needle valve. There is also a V4 that is opened (that bypasses the MFC)
That seems to be the missing info.
One more detail... is this after temperatures have returned to 25C?
