Find Wavelengh - Young't Double Slit
  • Thread starter Thread starter partly
    Double slit Slit
The discussion revolves around calculating the wavelength of light from a discharge lamp using the double-slit experiment formula. The provided values include a perpendicular distance of 2.35 cm from the midpoint of the slits, a slit-to-screen distance of 1.2 m, and a slit separation of 0.03 mm. The calculated wavelength is approximately 5.875 x 10^-7 m, which is within the range of visible light. Participants noted potential issues with significant figures but confirmed the calculation's validity. Overall, the solution aligns with expectations for wavelengths of visible light.
partly
For light from a discharge lamp, the first-order bright fringe is observed at a perpendicular distance of 2.35cm from the mid-point of the slits, when the slit-to-screen distance is 1.2m and the slit separation is 0.03mm. What is the wavelengh of the light from the lamp?
Wavelength = xd/D
x = 0.0235m, d = 0.00003m, D = 1.2m
Wavelength = xd/D = (0.0235x0.00003)/1.2 = 7.05x10^-7/1.2 = 5.875x10^-7m
Not quite sure where I've gone wrong ..or if I was even on the right path. If you could offer some assistance it would be much appreciated :) (p.s. hi, nice forum ^^)
Welcome to Physics Forums, :smile: and sorry about the late reply.
There might be an issue with the number of significant figures in your answer, but other than that it looks correct to me. Why do you think it is wrong?
I had the wrong figures in my head for the wavelength of visible light. My answer fits in there quite comfortably as it happens.
Thanks for your reply ..and thanks for your welcome too. Long time lurker, first time poster :smile:
Cool, glad it worked out.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
