Finding 2D coordinates in different frames
The discussion revolves around a homework problem involving the determination of 2D coordinates of a puck in different frames of reference. The inertial frame S is established with the puck's coordinates as x(t) = 0 and y(t) = u*t, where u is the puck's speed. Frame S' moves with a constant velocity v east, causing the puck's path to appear differently, while frame S'' experiences constant acceleration, making it non-inertial. Participants emphasize the importance of using sound reasoning to derive the answers and clarify that classical mechanics principles apply, avoiding Lorentz transformations. The key takeaway is that S and S' are inertial frames, while S'' is not, reinforcing the concept of Newton's first law.
futurphy
Hi guys, i need help for homework, it seems easy, but i can't do it:cry:, no calculation to do only writing 2D coordinates in different frames.
The hallmark of an inertial frame is that any object which is subject to zero net force will travel in a straight line in a constant speed. to illustrate this, consider the following: I am standing on a level floor at the origin of an inertial frame S and kick a frictionless puck due north across the floor. (a) write down the x and y coordinates of the puck as functions of time as seen from my inertial frame. (Use x and y pointing east and north respectively). Now consider two more observers, the first at rest in a frame S' that travels with constant velocity v due to east relative to S, the second at rest in a frame S'' that travels with constant acceleration due east relative to S at that same moment). (b) Find the coordinates x' and y' of the puck and describe the puck's path as seen from S'. (c) Do the same for S''. Which of the frames is inertial?
2. The attempt at a solution
for the frame S : x(t) = 0 and y(t) = v(0).t
for the frame S' : looks like a translation from S
Welcome to PF;
Do you think you'd be expected to use Lorentz transformations or is classical relativity OK (would you get the same answer?)
Which frames do you think are inertial?
I am not expected to use neither Lorentz transformations nor classical relativity, this is a classical mechanics problem. I think S and S' are inertial and S'' is not, because i think the first law of Newton is only true in S and S'.
The time in classical mechanics is absolute
You have to use one or the other.
Classical relativity it is then.
It is a matter of working out the v(t) in each frame ... you can do that by breaking the motion into components and adding/subtracting vectors.
OK - you have your head on right then. The trick to to show this mathematically.
You got frame S OK - only I'd call the speed of the puck u rather than v(0) to avoid confusion with the other frames (unless you happen to know that u=v).
Frame S' has a constant relative velocity v perpendicular to the motion of the puck... so an observer stationary in S' will see the puck go in both x and y directions.
S'' is just the same as S' except there is a constant acceleration involved.
You know a kinematic equation for this.
The real trick is relating these descriptions to the "Hallmark of an inertial frame".
It is seldom good enough to write down the correct answers, you have to show the marker that you got those answers using sound reasoning in order to pick up all the marks.
Trick: Your final answer should include the words of the question.
Thank you Simon Bridge you've been very helpful.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
