Finding an upper bound for a contour integral (Complex)
The discussion focuses on finding an upper bound for the contour integral of \(\int e^{2z} - z^2 \, dz\) using the ML inequality. The contour consists of two parts: C1, a circular arc from point A \((\sqrt{3}/2, 1/2)\) to B \((1/2, \sqrt{3}/2)\), and C2, a line segment from the origin to B. The lengths of the contours were calculated as \(\pi/6\) for C1 and \(1\) for C2. The user successfully applied the triangle inequality to estimate \(|e^{2z} - z^2|\) but encountered difficulties in determining the upper bound for \(|e^{2z}|\).
  • Understanding of contour integrals in complex analysis
  • Familiarity with the ML inequality for estimating integrals
  • Knowledge of parameterization of curves in the complex plane
  • Basic understanding of exponential functions and their properties
  • Study the application of the ML inequality in complex analysis
  • Learn about parameterizing circular arcs in the complex plane
  • Research methods for estimating upper bounds of complex functions
  • Explore the properties of exponential functions in complex variables
Students and professionals in mathematics, particularly those studying complex analysis, as well as anyone involved in evaluating contour integrals and applying inequalities in mathematical proofs.
Zeeree
C1 1. Homework Statement :
Using the ML inequality, I have to find an upper bound for the contour integral of \int e^2z - z^2 \, dz
where the contour C = C1 + C2.
C1 is the circular arc from point A(sqrt(3)/2, 1/2) to B(1/2, sqrt(3)/2) and C2 is the line segment from the origin to B.
I figured I have to find M1 and M2, and also L1 and L2 given the two different contours. Along C1, I have found the length to be pi/6 by integrating a parameterized equation of the unit circle from pi/6 to pi/3. I have also found the length along C2 to be 1 (no surprises here)
However, I've hit a bump when trying to find the upper bound for e^2z - z^2.
I figured I should use the triangle inequality i.e. |e^2z - z^2|
<= |e^2z| + |-z^2|
= |e^2z| + |z^2|
= |e^2z| + |z|^2
= |e^2z| + 1 (since the length of the line segment is one).
I'm kind of stuck when it comes to the e^2z. It's the same problem for finding the upper bound on C2 as well.
I'm sorry for not using Latex. I tried formatting it but it doesn't come out as intended in the Preview, so I decided not to take the risk of fudging it up and making it look confusing. I'm quite sleepy, sorry.
[/B]
If [itex]z = x + iy[/itex] then [itex]e^z = e^x (\cos y + i \sin y)[/itex]...
Thank you so much, I've got it :)
  • · Replies 16 ·
