Calculating Current and Phase Angle in a Series RLC Circuit
  • Thread starter Thread starter kdrobey
    Circuit Current
The discussion focuses on calculating the current and phase angle in a series RLC circuit with a 215-ohm resistor and a 0.200 H inductor connected to a 120 Hz generator. The user initially calculated the inductive reactance (Xl) as 150.796 and attempted to find the current using the formula Irms = Vrms/Xl, resulting in an incorrect current value. Participants pointed out the need to consider total impedance (Z) in the calculations, emphasizing that Z must be greater than the resistance alone. The correct approach involves using the formula Z = √(R² + (Xl - Xc)²), and the user was encouraged to verify their calculations for Z. Accurate calculations are essential for determining both current and phase angle in the circuit.
kdrobey
A circuit consists of a 215 resistor and a 0.200 H inductor. These two elements are connected in series across a generator that has a frequency of 120 Hz and a voltage of 235 V.
(a) What is the current in the circuit?
(b) Determine the phase angle between the current and the voltage of the generator.
Xl=2(pi)fL
Irms=Vrms/Xl
I used the equation to get 150.796 for Xl, then i plugged that into the equation Irms=Vrms/Xl to find current, but that gave me 1.558, which was not the right answer
Your second equation in #2 above is incomplete. The resistor and inductor are in series, so you must use their total impedance in the V = I * Z equation. Does that fix it for you?
I'm still not getting it. I used V=IZ. I have V, which is 235 volts right? still, i did not have I or Z. So i used Z=(square root of)R^2 +(Xl-Xc)^2, and I got .89 for Z. Then plugging back into V=IZ, (235v)=I(.89)=262.49A for current?
Hi kdrobey,
For these series RLC problems the impedance is
<br /> Z=\sqrt{R^2 + (X_L - X_C)^2}<br />
and so the impedance cannot be smaller than the resistance, so something is wrong there. What were the actual numbers you used to calculate Z?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
